Question about Sony Car Audio & Video
I have a 58 plate Mondeo with a Sony 6cd dab audio unit fitted. The problem I have is although my wife and I can make hands free outgoing calls we cannot receive hands free incoming calls on our phones even though the phones work as normal. Going through the phone menu on the audio unit I have found that the "incoming calls" and the "missed calls" are unavailable and no amount of button pushing seems to change these to available. Any suggestions, Ricky M.
Posted by pat_rick on
5 Related Answers
Anonymous
SOURCE: lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Posted on Jan 08, 2008
Anonymous
  • 7752 Answers
SOURCE: No audio on outgoing or incoming calls
dakarjohn - you need to replaced the speaker on the phone.
GUEST - replace the speaker on the phone.
SAEFUJI - you need to replaced the flexcable on the phones, contact your mobile provider or your local operator for assistance.
Posted on Jul 03, 2008
Anonymous
  • 80 Answers
SOURCE: my phone says "service unavailable"
Service unavailable mean you don't have any network. Check with your service provider if they have barred your service or not. This has nothing to do with mobile phone. If there will be no services from your service provider you will not be able to call or send message or receive calls.
Summary: Check once with your mobile service provider.
Posted on Dec 28, 2008
Anonymous
SOURCE: no connection outgoing and can't answer incoming calls
I unplugged base connection for about a minite and then reconnected and they started working agian...Thanks
Posted on Mar 11, 2009
Anonymous
SOURCE: Samsung Impact pnone. Cannot send a text message.
go to message setting, text message, text meassage center, then try changing to another center, ( i've got 3 dif centers to pic from but only the first one lets me send text messages)
good luck
Posted on Jan 18, 2010
Unable to play and eject and cd's from sony 6cd in my ford mondeo Mar 2007 model
some mechanical problem inside your stereo cd unit that maybe broken parts, circuits, jam or foreign object
1helpful
Hi, I've just aquired an '09 Ford Mondeo 6000CD RDS EON radio/cd on ebay. Can it be fitted to a Mondeo Ghia on a '52 plate?
It would have been better to find this out first before you bought this unit, but yes it should fit as long as your vehicle has a double din facia fitted, if not you can change the dash
2004 Ford Mondeo Sony 6cd radio manual
Ford 6006CD 6 change. I have the code! how do enter it?
3helpful
2answers
Ford mondeo TCDI ghia x but no Sony audio car manual
Try here
http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Audio%201/audio%20guide%201%20(cg3508en)%2001-2006.pdf
Ford Mondeo 2002 6CD auto changer. Error message E 3
According to the Ford Handbook Error Message E3 is "Mechanical Error " and their suggestion is "Install a new Audio Unit "....which is not very helpful
There`s not much that can be done as a D-I-Y solution with these CD Units apart from cleaning the laser lens with a cleaning disk+solution (from your local audio Store or Ebay etc)....or a full reboot ...by disconnecting the unit from the battery for 20 minutes , replacing it and hoping that it will have reset itself.
Make sure you have the correct radio code before attempting this disconnection procedure ( If not, just post the Serial Number (found on a label on the casing) and someone will calculate the correct code.
2helpful
2005/2006 ford mondeo sony 6cd audio player
you can use what is called a line level converter, which taps into your speakers to convert the signal to rca cables. that is about all i can think of since i don't know the model number of the cd player
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
