How to Install a Printer for a Computer
Level of difficulty: Easy
Having a printer is very essential when it comes to printing documents
whether a computer is for personal home use or in the office. You can
also use high-end printers to develop quality pictures. The printer
that you would install should be appropriate to the hardware of the
computer. There are printers using the parallel port and some
prototypes connected through the Universal Service Bus (USB) port. In
order to install a printer onto a computer, you should first check the
BIOS settings if the parallel port is configured appropriately.
Materials Needed:
- Printer
- computer with Enhanced Parallel Port (EPP) or Extended Capabilities Port (ECP)
- printer installation CD
- Internet connection (optional)
Step 1
Turn on the computer. Wait for the computer to completely load the OS.
Step 2
Attach
the printer cable to the corresponding parallel port. After you
securely connect the printer to the computer, turn on the printer.
Windows will automatically detect the new printer and would prompt you
to install the required drivers. Some printers may not be detected
automatically by the computer. To manually detect the printer, click
the “Printers and Faxes” available on the “Start” Menu. Double click
the “Add Printer” icon to launch the Add Printer wizard. If the
computer still did not detect the attached printer, unplug and adjust
the connection of the printer to the computer.
Step 3
The
wizard would ask you to choose between a Local Printer and a Network
Printer. The computer searches for the connected printer after you
select the type of printer.
Step 4
The
computer prompts you to install the needed driver. The printer usually
comes with an installation CD which contains the drivers of the
printer. Insert the installation CD on the CD tray. The computer
automatically detects the driver files on the CD.
Step 5
You
need to manually detect the driver required for the installation just
in case the driver is not detected. Select from the predefined list of
driver software depending on the manufacturer and the model of the
printer.
Step 6
You
may now proceed to perform a Windows update if you still cannot find
the driver for your printer. You need to connect to the Internet in
order to gather components from the online Windows product support.
Step 7
The
computer finalizes the installation procedure after the driver is
successfully installed. A notification would appear informing you that
you have successfully installed the printer. A printer icon would
appear on the taskbar. This enables easy access to the configuration
and maintenance settings of your printer.
Hope this is very helpful. Don't forget to rate me..:-) Thanks..
Click here
click on above link and downlkoad driver for windows 7.
Then install it in computer then connect printer to your computer then it works fine but if still it found as new hardware then click on no at this time then click on "install driver from specific location .Then locate your driver folder thne next then it install driver from downloaded folder..
SOURCE: Printer driver installation
you can try the following sites
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
www.driversdown.com www.soft32.com,
driverzone.com,
www.driverfiles.net,www.download.com,www.driverskit.com,www.driverguide.com
SOURCE: driver hp laser jet 1020
Here's a link to download your driver software free from HP. Just select your operating system (XP, Vista, etc...). Hope that helps you. :)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=439320&lc=en&cc=us&dlc=en&submit.y=2&submit.x=6&lang=en&cc=us
SOURCE: how i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
SOURCE: I want download driver windows 7 64bit for HP
You can download the required driver from manufactrurer's site by clicking this link
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
