HP iPAQ h6315/h6365 Pocket PC Logo
Question about HP iPAQ h6315/h6365 Pocket PC
Unlocking Hp ipaq H6315 t-mobile (phone not ready for unlocking)
Am trying to unlock my Hp ipaq H6315 t-mobile but it tells me your phone is not ready for unlocking, I have the code, what should I do?
Sim unlock HP iPAQ Data Messenger Smartphone
hi you can use codes to unlock your hp ipaq data messenger.you can get the codes from this site simpleunlocking here they ask the country and the network name to which your mobile is locked .finally they will send you the codes to unlock your mobile along with the instruction about how to use the codes in your mobile.
How to unlock hp ipaq hw6920?
The HP IPAQ HW6920 locked in which Country's Network ?
You can Unlock it using the Unlock code from the website
Superunlockcodes there you can get the Unlock code at low cost and unlock it,check code for your network lock,Country!!!!
HP IPAQ HW6920 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HP IPAQ HW6920 mobile phones. If you enter over a certain amount of wrong unlock codes on your HP IPAQ HW6920 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON the HP IPAQ HW6920 with a sim card that is Not accepted.
2 - The HP IPAQ HW6920 will prompt you for an unlock code.
3 - Enter the unlock code, which you can buy from our website.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your HP IPAQ HW6920 is locked to.
Each HP IPAQ HW6920 mobile phone has an unique unlock code. You can buy the unique unlock code for your HP IPAQ HW6920 mobile phone using the form above.
1helpful
Hp ipaq h6315 unlock code
Get the unlock code here http://www.wickedunlock.com/unlock-your-phone/rs11wp2/ and also get the unlock instruction in the same site....With the help you can unlock easily....
UNBLOCK
There is a code that is unique to your phone only. Search on eBay (ipaq 6315 unlock code) and buy the code for about $20. You will need to give them the IMEI number located behind the battery.
How to unlock hp ipaq 6315
Not sure you still need a solution for this problem, but this may help someone else who is searching for the same solution.
You need an unlock code. Each unlock code is unique to each phone. You can search on Google or eBay and find a seller. I got one on eBay for $20. You have to provide the IEMI code from the phone. It's on a tag underneath the battery. They will use the IEMI code to get your unlock code and email you the code along with the instructions. Read the instructions all the way through before you start. I was able to do it the first time and it worked.
3answers
I have a T-mobile HP iPaq from Canada. I have moved to India and haven't used it in Canada for more than 90 days. How to get it unlocked?
As long as you have been a T-Mobile customer for more than 6 months you can just call Tmobile customer service and tell them you are moving out of the country and need the unlock code for your PDA they will ask for your IMEI number which is under the battery in most cases. they will email you the unlock code and procedures.
Pc doesnt see ipaq h6315
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Hp ipaq h6315
If it is blinking red, it means that your battery is having issues. Try replacing the battery and see if it fixes the problem.
2helpful
Hp ipaq 6300
Get the unlock code here theunlockspot.com and also get the unlock instruction in the same site....
Top HP Computers & Internet Experts
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
