SOURCE: d-link dwa-130 wirless
Same problem here ... I installed the beta driver 1.2 and seems to help.
The Dlink DWA-130 is an antenna designed to pick up long range signals from gateway sources. I use it as my primary internet access here in Korea and it does the job it is supposed to. It was not designed to be primarily a short range device, however a person can adjust the power settings in the device driver under Device Manager. The problems people are mentioning about audio cutting off is not due to anything other then the operating system ( not the device driver for DWA-130 ) not responding well to new sources. I have seen all the issues mentioned so far. It works so well I am thinking about buying another one to test co-phasing them... That might be a while yet tho. What I am wondering is, did anyone else besides myself notice the lack of driver installation from the driver CD into Vista. I've had my DWA-130 for about a year now and it is exposed to winter temps and summer rain covered only by a plastic garbage bad for protection. Still working great and I use it constantly. I have seen 400 kB/s using this device ( yes I wrote that correctly ) which is 4 times the speed of my old wired Motorola cable modem.
SOURCE: D-Link DWA-130 running Vista
OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
SOURCE: dlink dwa 130 wont stay connected
I had a very similar problem with my Netgear, I assume your Netgear is 802.11n standard router and your wifi card is probably integrated which means it only supports b and g standard. The only solution is either to buy a 802.11n compatible wifi card or to kick the speed of the rounter down to b & g compatible more.
SOURCE: connected a 2wire adapter, downloaded driver, but
Make sure the N router is also sending a broadcast for B/G mode, as the 2wire adapters do not support N technology. You can login to your router by typing "home" or "192.168.0.1" or "192.168.1.1" in your web browser and check the wireless settings on your Dlink to see if it supports these methods.
