Hunter Pipes Posted on Nov 11, 2009
Blinking transport lights and won't eject - Tascam 102 MKII Single Dual Cassette Deck
My Victrola VTA-200B CD player isn't working properly
The player is having problems reading the CD. This can be for several reasons. Remove the CD and see if a different one has the same problem. This way you can find out if it’s the player or just the CD. Wipe off the smudges on the back of cd. If cd has too many scratches or smudges it won’t play. There can be many other reasons why it doesn’t play.
1helpful
In tvs speed 40 printer all led light are blinking
follow these steps
1) Press ST1+READY button together
2)Turn on the tvs speed 40plus passbook printer
3) The 4 LED will blink 4 times. Release the button ST1+READY immediately after 4 blinks
4)PRESS ST1 - ST1+READY+EJECT starts blinking
5)again PRESS ST1 - ST1+EJECT+ST2 starts blinking
6)again PRESS ST1 - ST1+EJECT starts blinking
7)again PRESS ST1 - ST1+EJECT starts blinking
8)again PRESS ST1 - READY+EJECT starts blinking
9) printer is READY wait and PUT PAPER.
10) The paper goes in and comes out 3 times. will take about 2 minutes.
11) Paper ejects automatically after printing.
12) turn off the printer and turn it on.
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
Cassette stuck in left side, won't eject
The mechanism transport need work to allow the unit to get back to the stop/Eject cam position. Without that the deck is not going to work. This is usually but not always due to a small rubber belt. That is not all that is needed but the primary reason for that failure.
1helpful
My VHS tape is stuck and won't eject or plsy
The transport mechanism ff/rewinds and drives the tape back into the cassette when eject is used.
Most likely a bad belt or the drive idler wheel (rubber or geared). Unit would have to be taken apart to "see" what is not happening.
My dvd player is acting weird its skipping and then restarting the movie from the beginning and now its not ejecting the disk and the is just blinking. also when i try to go to the "blu-ray"...
The easy first try is obvious, clean disk first then laser ( with a laser cleaning disk) then suspect laser or laser transport drive.
pete
Cannot get a connection from wireless internet to game-
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
1helpful
One flashing red light on xbox360 ( not red ring)
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Top Tascam Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
