Question about Dewalt Heavy - Duty 5" Random Orbit Sander - D26451
Turns on, spins, but doesn't randomly rotate
Turns, but doesn't randomly rotate
Posted by rjames606 on
Joe Hogan
  • 10,865 Answers
Hello. The Dewalt random orbit sander has a 3 year warranty so if yours is still under warranty you should contact a dewalt service center and not repair it your self except for this
As part of CFS (Controlled Finishing System®), your sander is equipped with a replaceable
disc (F) which is located between the pad (C) and the sander body (G). It is designed
to increase the dust collection efficiency and control the pad speed while the unit is off the
work surface. The disc is designed to be a consumable part and will occasionally need to be
replaced. Replacement is necessary when the pad speed increases very dramatically when
the unit is lifted from the work surface.
TO REPLACE YOUR CFS DISC (FIG. 6)
CAUTION: Turn off and unplug the tool before making any adjustments or removing
or installing attachments or accessories. Be sure the switch is in the OFF position.
a. Remove the three screws from the bottom of the pad.
b. Remove the pad (C).
c. Remove worn CFS disc (F).
d. To install the new CFS disc, place the spring side of the disc toward the sander.
e. Align the notches (H) on the CFS disc with the seams in the sander body.
f. Replace the pad and the three screws. Be careful not to over-tighten screws.
Posted on Nov 11, 2009
Anonymous
    New Friend:
  • 7 Answers
Inside there is a counter weight sytem that causes the random sanding pattern .You will have to take apart unplug first!!!! as yo take it apart notice the procedure you had too use.Inside at the bottom of things you will find a little housing that the shaft from the motor goes into examine all parts for damage some part in there has broken and needs replaced go to there web sight for parts breakdown first to get a idea of what you will find as you disassemble the sander .And to find your replacement part.
  • Anonymous Nov 11, 2009
john h
    Top Expert:
  • Dewalt Master
  • 23,504 Answers
Remove pad and clean and lube cam
Maytag Neptune rotates but not in spin mode
see the causes:
t doesn't pump or spin
frozen puller or belt broken pump, lid switch defective
It pumps, but doesn't spin
lid switch defective+motor coupler defective+belt broken+clutch worn+drive motor faulty+transmision not shifting properly+basket worn.
It spins only with the lid closed
lid for security reason.
see the diagram
Jun 19, 2012 | Maytag Neptune MAH5500B Front Load Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
Not spinning to let out water
Hi
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Also check this link bellow:-
http://www.ehow.com/how_5030854_fix-machine-not-drain-spin.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 02, 2011 | Whirlpool Washing Machines
My Maytag washer m.mtw58701tw0 doesn`t drain or spin and I just replaced the motor with a new one. What could be the problem?
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. Please rate my answer as 4 thumbs up. thanks. Joe
Oct 02, 2010 | Maytag Washing Machines
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
Dewalt Heavy - Duty 5" Random Orbit Sander - D26451 Logo
290 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
efs_perpends
efs_perpends
john h
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
