Texas Instruments TI-83 Plus Calculator Logo
Anonymous Posted on Nov 11, 2009
I am in a math class and i have a TI-83 plus calculator and we are doing stuff with polynomials. how do i type in to it something like (5x)(6x) and get the answer 30xsquard
Thushanth Sitham
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Nov 11, 2009
Thushanth Sitham
Contributor
Level 1:
New Friend:
Answers
7
Questions
5
Helped
1959
Points
22
Ahh well maybe i not familiar enough but i think you need programs 2 do that, you get a usb cord wire and look up for free program from ti site they should have it there and then you can download some program and run it.
to clarify your problems type ti-83+ on google and see the texas instrument site where they should have program and cord for sale.
Testimonial: "Thanks"
How to solve trig functions using ti-83 plus
Your best bet would be trying a math package on ti-calc.org - you can usually find something that does what you want there. You'll need a cable and the software to download these programs to your calculator. Here's a link to the trig section:
TI 83 84 Plus BASIC Math Programs Trigonometry ticalc org
How do you calculate the 6th root of 1.47762 on the TI-83 Plus
Use the xth-root function, which should be the fifth item in the MATH menu.
Press 6 MATH 5 1 . 4 7 7 6 2 ENTER
1helpful
2answers
How to find the polynomial roots in TI-83 Plus
One way is to use the Polynomial Root Finder and Simultaneous Equation Solver app.
Press the APPS key, then select PlySmlt2 and press ENTER. Press ENTER to get past the opening screen, then select "POLY ROOT FINDER" and press ENTER. Select the order of the polynomial and other settings as desired. Press F5 (the GRAPH key) to go to the next screen. Enter the polynomial coefficients, then press F5 to solve. The next screen will show you the roots (unless you selected real roots and the polynomial doesn't have any real roots).
If you don't have the app installed, you can download it from
http://education.ti.com/educationportal/sites/US/productDetail/us_poly_83_84.html
1helpful
What would i put a program that factors polynomials and leaves it like "(x+_)(x+_) into a ti-83 calculator
Here is a link to the math archives of ticalc.org for Ti83Plus/TI84PLUS.
Explore the folders and read the descriptions of the programs. You may find what you seek.
Hope it helps.
How do I solve a polynomial equation: x^4+5x^3-3x^2-43x-60 on a TI-83 plus graphing calculator?
Sorry, but what you wrote is not an equation but a polynomial expression. You want to solve the equation x^4+5x^3-3x^2-43x-60 =0.
The solve( command, can only be used with real numbers.
The solve( is available through the CATALOG : [2nd][CATALOG], scroll down till you reach the command. Highlight it and press [ENTER]. The command echodes on main screen as solve( .
You complete the command by entering the expression (not the equation), the name of the variable you solve for, the initial guess , and { lower limit, upper limit} between curly brackets, and the closing parenthesis.
Exemple:
solve (x^4+5x^3-3x^2-43x-60 , x,0 {-5,0} ) [ENTER]
should give you the negative root,
solve (x^4+5x^3-3x^2-43x-60 , x,0 {0,5} ) [ENTER]
should give you the positive root.
It is implied that the expression is 0, so you should not insert =0, otherwise you get an error. Here for the lower limit is -5 you must use the change sign symbol (-) under the 3 key, not the regular MINUS.
You may ask how I knew that there were two roots when the equation is a quartic? By first graphing it to have an idea about where the roots lie and how many there are. You should always do that to speed up the search.
There is another way to zoom in on the roots: by drawing the graph and using the tools accessible under the [2nd][CALC] menu, namely the option [2:Zero]
The resolution of the TI83/84 is not good enough for this function that grows too fast, but I am inserting a picture of the curve from another calculator with a much better resolution.
Hope it helps.
Graphing on ti-83
Press the y= button on the far left under the screen then type (1/5) then press the X,T,n button then minus 2. Press the GRAPH button on far right under the screen.
4helpful
TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
TI 83 TI 84 and TI Nspire
Yes, the Ti nspire not only functions as a ti83 but, also operate w/ nice advance math software that any teacher would envey. It comes with the ti83 keypad plus software and great instructions to help the instructor at all levels of math learning. I don't know any better and it is a beautiful plan that ti has set up.
3helpful
2answers
TI 83
Yes you can use it, here is the formula: Y= V(t+ (i/c))^(tc) V=amount put in, t=time, i=intrest rate, c= amount of times it is compounded.
(I know this because I have a TI-83 calculator)
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
