Question about Haier Refrigerators
Have a 14.3 cu ft top mount refrig/freezer bought in 3/04. the fan in the freezer is making an awful noise
  • 553 Answers
Eventualy, the bushing inside the fan motor because of continious usage will need to be replace , this parts are replaceable. it's been five years now, and i suggest it's time to general maintenance check up your fridge to avoid more problems.
Posted on Nov 11, 2009
Anonymous
SOURCE:
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
My fridge is making a god awful noise... it's still cooling, but the noise is off and on and each time it comes back it's louder and louder.... any suggestions??
When do you hear the noise? What is the refrigerator doing when the noise comes back?
If it is when the compressor kicks on, I would check the mounting brackets for the compressor and make sure they are tight.
If it is a clatter then I would check the colling fans (top and bottom and make sure the blades are striking something.
Where you say it is getting louder and louder, I would check for ice buildup on the evaporator fan in the freezer section.
Jun 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refrigerator portion of refrigerator is not working but the freezer is working fine.
Look in back of freezer and see if you see ice formed. If you do, it's in the defrost timer, thermostat or heater.
If it has no ice-check the evaporator fan motor and make sure it's running.
One last thing: check and make sure the refrig and freezer is at factory settings. Sometimes people turn them up or down.
Nov 26, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Frost free freezer in my frost free refrigerator
the noise is quite possibly the freezer fan cutting ice behind the wall
you may have an issue with your defrost system
Oct 06, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Would not shut off
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 24, 2007 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
71 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
