Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Had one last week and now there are 6. they are
Had one last week and now there are 6. they are tiny white dots that are randomly placed. I have a samsung 46in. dlp hdtv. it's about 2 years old.
Posted by blakeoftexas on
Anonymous
    President:
  • 1,462 Answers
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Posted on Nov 11, 2009
Shemus McNault
    New Friend:
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Posted on Oct 13, 2012
My Mitsubishi 65 inch HDLP had one tiny white dot
The DLP chip is faulty. The DLP mirrors are sticking in various states of Off to mid positions. Watch this video. It explains a lot...
Sep 13, 2014 | Televison & Video
White dots on screen
Your DLP chip is failing. The tiny micro mirrors within this chip are stuck. More white dots will appear over time until it looks like a star field on your screen. Most places will tell you that you need a new light engine, however you can replace the DLP chip itself and it will take you about 30 mins. You can find the chip online for around $349 but I think I have DLP chip you need brand new for $225. If you are interested in this contact me. [email protected]
Feb 27, 2011 | Mitsubishi WD-Y577 Television
Hi, My Viewsonic vg2021wm says "No signal digital" There is white paste around couple of caps and couple of caps have tiny black dot above them. There is also one componet I didnt identify:...
All the caps with the white paste or dots in the middle or swollen tops (convex) need to be replaced and jointly could be responsible for your hassle. Don't confuse a leaking ca with one that has some real hard epoxy like material or glue (usually white) holding it in place.
Sep 01, 2017 | ViewSonic VX2235WM Monitor
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
color wheel is failing and this repair cost thousand or more most of the time so i guess it would be better to dispose of or you may get lucky and find one on ebay but make sure you take care in installing
Oct 19, 2009 | Samsung Televison & Video
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on screen of 50 Samsung DLP
Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
Jul 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Two week old Samsung LCD TV has a tiny white dot on screen when black.
it sounds like a pixel is messed up. if its only two weeks old, then your best option would b to exchange it and get a new one
Oct 21, 2008 | Televison & Video
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
1,332 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
