Question about Rangemaster 110 (Gas) Kitchen Range
How do i bypass the clock on my rangemaster 110 cooker
Posted by nickydoble on
  • boo2yoo
    boo2yoo Jan 06, 2019
    Our clock has stopped working, however, we discovered that when the hobs were on, or the hotplate the clock would start working again! We now use a hairdryer to start the clock, may seem odd but it works, We hold the hot air over the clock and it's function buttons and hey presto, after few min's the clock starts to work which means we can now use the oven. My theory is, the clock and perhaps it's wires have prob got cooking fat trapped around its mechanism, so when we use the hairdryer, it must simply melt off the fat! Then as the oven cools it sets again making the clock and oven unworkable. Try the hairdryer test yourself, works for us every time. Kim :)
Anonymous
    New Friend:
Have had trouble with our timer on our Rangemaster 110 so ordered a new timer only to be credited as it is no longer available. Dont realy want to buy a new cooker this side of christmas, any way of bypasing the timer ?
Posted on Dec 05, 2010
j_burrell55
    New Friend:
    Problem Solver:
  • 5 Answers
How do I disable the auto function, I think the hotplate needs to come out, can't get to the wires ?
PLEASE HELP
Posted on Apr 04, 2011
Anonymous
    New Friend:
  • 4 Answers
Here is a link to get the Rangemaster pdf manual for the 110 dual fuel. Copy and paste to your browser.
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/ClassicDeluxe110DF_06-06.pdf
Posted on Dec 20, 2009
Mike Carew
    Master:
  • 969 Answers
2 Related Answers
Anonymous
  • 3 Answers
SOURCE: rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Posted on Nov 24, 2008
dervishy
  • 149 Answers
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me [email protected]
Posted on Mar 27, 2010
Clock and ingnition not working on a rangemaster dual fuel stove
  • Hello David,
    when the clock does not work, the (left hand) oven will not work too I suppose.
    Often when the clock does not work, it is only the timer that does not work. In that case, the timer can be bypassed. The oven still works then, but without the timer and the clock will also work as a clock.
    So no timer.
    When it is an older rangemaster, and the ignition does not work, then probably are some wires leaking. I that case the power for the spark does not come to the burner sparkplug.
    But when all plugs do not spark then there are 2 possibilities I think.
    1 the ignitor is gone
    2 the ignitor does not get power
    I hope this helps, I wish you a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Mar 05, 2017 | Rangemaster Kitchen Ranges
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Feb 28, 2017 | Rangemaster LEISURE 55 & 110 FAN OVEN...
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
Jan 19, 2016 | Rangemaster Range Cookers Kitchener 110...
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Nov 24, 2015 | Kitchen Ranges
The ovens in the rangemaster will not work as the timer is not working. The timer will not flash and when it does decide to flash it goes right back to non flashing zero. Can i use the cooker without...
Try putting your grill on low for 30 minutes to one hour the clock should start to flash then leave to flash for five minutes after which press reset. It worked for me on my rangemaster 110 (gas)
May 15, 2011 | Rangemaster 110 (Gas) Kitchen Range
How do I set the clock on the oven
download cooker manual from Rangemasters web site they are free
Apr 25, 2011 | Rangemaster 110 (Gas) Kitchen Range
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Cooker stuck on auto
Comes on like this when switched on, hold down the left 2 buttons on the clock controls then whilst still holding them pres the right hand button
or manuals available here...
http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Sep 18, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster 110 (Gas) Kitchen Range Logo
4,577 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
jdthefixer
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
