KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
Anonymous Posted on Nov 10, 2009
For the Kitchenaid model#kudso1flbl2 type 5770, the door will drop like a rock, if not supported. Does this sound like it requires a spring? Is there a way to fish out or reattach the old opring? How hard is it to install a new spring? Thanks Jeremy.
John Riley
Level 3:
  • Master 441 Answers
  • Posted on Nov 11, 2009
John Riley
Master
Level 3:
Answers
441
Questions
Helped
138558
Points
1344
Very easy, take out the two screws from the counter that hold the unit inplace and only pull it out a few inches, then you can angle it a little and get to the spring. They are on the sides at the bottom (you can miss em) if its broke go to marcone.com and you can get a replacment, or just put it back if not broken
Testimonial: "I haven't tried it yet, but it sounds easy enough. Thanks. "
KitchenAid microwave oven model kcms 1555. The button for the door does not have any tension as a result the door will not latch close, light will not turn off
It sounds like the door spring had broken. Take the covers off and it should be apparent what had happened. It may be a part you can get at the hardware store or it may be an OEM part.
1helpful
4answers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 • Dishwashers
Door falls open
The cables that are connected to the springs are broke, atleast one anyway. You'll need your model number off the machine to get them from a parts dealer. once you have them, pull the machine out a little ways and they install on the left and right side lower area.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
I have a KitchenAid KUDS01FLSS2 and was wondering if it is normal for the door to fall open... what I mean is the door requires to be supported when opening. Otherwise, the door will swing down and almost...
Yes indeed that sounds exactly like the door springs being broken. The springs are fairly easy to replace, what needs to be done to replace the springs is remove the lowest service panel/kick plate and hook the springs on the tub support frame/leg and the other end goes on a notch in the door hinges. The part number for the spring is 8270182 they could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
midwestapplianceparts.com
Even though only one may be broke its advisable to replace both at the same time.
Good luck,i hope i have been able to help you fix your dishwasher,
Gene
Aug 13, 2011 • Dishwashers
1helpful
I have a KitchenAid dishwasher. The door drops
either the door springs are broke,worn out or possibly the door balancers need replacing
Jan 10, 2010 • Dishwashers
Door drops hard and i have an error code 7 -
The door slamming open is a broken spring/springs. They are very easy to replace - remove the screws holding the dishwasher in... pull out slightly and replace with good ones on the sides.
Can you clear the error code by shutting off power to it?
(Mdl # helps)
1helpful
I have a stainless steel Kitchenaid dishwasher and the door drops hard when I open it instead of requiring you to push it down if you want to open it fully. Seems like a spring is broken. Any ideas?
there a good chance the springs popped
or the ropes came off the pullys take off the toe kick and peek in on the edges you should see exactly whats going on
Door drops to floor
sounds like springs and cables on door hindge.
6helpful
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
2answers
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
