TV made a loud crack or pop and the screen went black
TV was on, when it made a loud crack or pop and the screen went black. The power light is on, but there is no picture or sound. Pressing the power button, does not turn the power light off. I've re-set the surge protector and unplugged the TV, with no change.
Posted by c_oakley110 on
Shahid Electronics
  • 10,594 Answers
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
Posted on Nov 10, 2009
Samsung plasma screen went black. Was watching tv, heard a loud pop and the screen will no longer turn on. You can hear the tv turn on but no picture. Power is still working, just a blank screen.
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
Jul 28, 2017 | Samsung Televison & Video
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
May 30, 2009 | Vizio GV47LF Television
I heard a loud pop then tv screen went black, now
hi friend,,,,,,,
i think due to high voltage resistor in dma board has blasted,,,,,
did u see any burnt marks,,,,,,,,,reply me
thank u,,,,,,,,
May 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Jvc av-32fa44 tv--loud pop, then off and won't turn back on. buy new?
Its the power cap mine did the same thing about 11 months into daily use
Oct 24, 2008 | JVC AV-32FA44 32" TV
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Jul 16, 2008 | Toshiba 50HP66 50 in. Plasma Television
206 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
