Cars & Trucks Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel pump wont stay on wont start replace the
Fuel pump wont stay on wont start replace the pump still thesame 1998 dodge dotaka
  • Anonymous Mar 15, 2014
    fuel pump replaced still wont start
Anonymous
Level 3:
President:
  • Master 1,201 Answers
  • Posted on Nov 10, 2009
Anonymous
Master
Level 3:
President:
Answers
1201
Questions
0
Helped
618032
Points
4388
The pump is not supposed to stay on, you should only hear it for a second or two when the ignition is turned on. At least you know the pump is working. There must be a problem in the ignition system, like no spark, do to a bad coil, ignition module, without testing it's hard to say.
My 1998 dodge neon wont start cranks but doesn't
You say the relays are good - - are you getting power out of the ASD and fuel pump relays ?
98 gmc savana 350 v8 was running then sputtered would not go turned off now wont start i checked and replaced fuel filter still no luck it will start with starting fluid but wont stay running
sounds like a fuel problem. could be a fuel shut off switch, fuel pump relay, fuel pump. Possible bad electrical plug connection to pump
1helpful
1998 Dodge Caravan. engine dies and wont start. fuel pump was changed twice but i get a few miles & dies again & wont start. im thinkin fuel filter is plugged....
It might be your fuel filter. Also, Dodge and Chrysler is bad for fuel pump failures. A clogged fuel filter can cause this. Also, you might not be getting enough fuel pressure. There should be a test port on the van, where you can test the gas pressure. You also have a fuel pump relay or switch. This could be bad as well. Hope this helps you.
1helpful
Trying to find the fuse that control the fuel pump. the truck starts but wont stay running once the gas is used up in the carb. figure it is the fuse that is the problem or the relay whatever it is called....
Donna,it does not have a carburetor,and no gas to be used up,but the fuel pump is under the hood in the relay box,I believe on the drivers side.
98 dodge wont start
Did you consider putting gas in it?
Did you chek the fuel pump if it works?
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
