Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
I want to delete the memory from my panafax uf 885 fax machine.
    President:
  • 3,085 Answers
Press
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for machine to reboot
Posted on Nov 10, 2009
I would like to forward my faxes to another fax machine. the fax machine that i am using is panafax uf-885. how do i do that
Try entering *72########### where #=fax # that you want to forward to. To end forwarding, enter *73. This depends on if your carrier supports call forwarding.
Jun 10, 2011 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Can the panafax uf-885 be used thrue a modem on my computer
No, DSL is DIGITAL fax machines are ANALOG and will not work reliably on DSL.
Jan 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF - 885 unable to send faxes direct
Hi BrendaAsh,
Thank you for the above information.
Please ask rlandriani to access the user parameters on the fax machine and turn the Quick Memory XMT to "Off" or "Invalid".
This should set the machine for direct manual sending without memory intervention.
Regards
Gavin.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
No. If this is needed, make sure to turn on automatic reports
May 01, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
421 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
