Hello. I can assist you. Just look at the top side of your player and you will see the holes. Using a piece of paper, lay out the holes on the paper as they are on the unit itself, starting out with the length of the unit, and the depth of the unit that you want under the cabinet. Once you have every measurement including the hole locations you have your layout template. Now, just make a small hole where every screw goes, and tape the template up to the cabinet base paying attention to keeping it uniformly away from the back wall and the front of the cabinet. Use a marker to mark the screw holes and you will be good to go.
Testimonial: "thank you very much! I was hopng I could find an actual print-out of the ge spacemaker cabinet disk tenplat but this was helpful..thanks again"
