Question about Philips 42PF9630A 42 in. Plasma Television
Menu keeps popping up
The menu keeps popping up on my Philips 42PF9630A/37. I have unpluged it and pluged it back in. The picture comes up and then the menu pops up.
Posted by wgshook on
Anonymous
    New Friend:
  • 117 Answers
Check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Posted on Nov 10, 2009
THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Nov 29, 2009 | HP PL4260N 42 in. Plasma HDTV
Phillips 37 in menu screen keep coming up?
Download the latest software from the Philips website and place it on a USB stick.On the Philips site you will find a manal how to go on with uploading the software to te TV set.
Nov 02, 2009 | Philips 42PF9630A 42 in. Plasma Television
My tv menu keeps popping up every few seconds.
MENU KEEPS POPPING UP WHILE WATCHING A PROGRAM. I REPLACED BATTERIES ON REMOTE CONTROL AND HAVE UN-PLUGGED THE TV SET. I OWN A 42INCH PHILIP PLASAM TV MODEL#42PF9630A-37
Oct 02, 2009 | RCA R61WH76 61" HDTV
I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Aug 03, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
Nov 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
'42pf9630a 37 philips tv only displays menu
Check the software and if is not BX23U-1.5.0.0_03531 upgrade it by downloading the software onto a usb stick at www.p4c.phillips.com if that don't fix the issue replace the SSB part number 310432842611
May 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Menu 42PF9630A 42
go to www.ceusasupport.philips.com and upgrade your televisions software to the latest version. this is a very common issue.
Jan 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
2,440 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
