Question about NorStar Meridian M7310 Phone
On my phone system (M7310) I only want one phone to ring when calls come in. currently 2 ring. how do I turn the other off?
Posted by chalmers198 on
george peters
    President:
  • NorStar Master
  • 860 Answers
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programmingon my phone system (M7310) I only want one phone - 2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Nov 10, 2009
I have Norstar M7310, we have 6phones in our office and question on one of phone ext. 241. when calling ext.241 all phones are ring, but when calling other ext.phone is okay will only that phone rings. ...
Sounds like extension has put the phone on transfer. You can try these steps on the Extension 241 phone and see if it will correct the issue. 1. Press the Feature button, then * 2
2. Push the button you want to program
3. Display will read "Intercom #:__"
4. Enter the extension number
Jan 07, 2011 | NorStar M7310 Corded Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Call display won't work as the phone system M7310 keeps picing up on the first ring. I have changed the Auto Attendant and the ccr # of rings but that doesn't help
Try this - keep the handset in the cradle and press:
"Feature 9 8 2", the system will prompt you for a password.
The default password is: "O P E R A T O R"
Scroll through the items by pressing "Next".
The "Answer Lines" should be changed to N(o) to stop the Auto Attendant from answering. You will need to wait at least 2 rings for the system to process the Caller ID info & display it on the phone.
Good Luck!
May 13, 2010 | NorStar M7310 Phone
Call display won't work as the phone system M7310 keeps picing up on the first ring. I have changed the Auto Attendant and the CCR # of rings but that doesn't help
It may be that you have the forward no answer parameter set to 1 ring on ANY of the phones you have programmed to ring on those lines. Make a call to your system from your cell and see what answers....the auto attendant (you can dial another ext) or a voice mail box. If your system is equipped, we offer remote programming services.
www.dyna-tech.us Hope this helps . Bill
Mar 22, 2010 | NorStar M7310 Phone
We have a Norstar - Meridian M7310 phone system. Today for some unknown reason when an incoming call comes in, the ring is two short rings rather that the "longer" ring that we normally have. I have...
The two short rings is telling you that the call is either a transfered call (answered by someone else and transfered) or answered by an auto attendant and transfered. Watch the ringing phone when the call comes in and see if the intercom LED blinks.
Bill C. www.dyna-tech.us
Mar 12, 2010 | NorStar M7310 Corded Phone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
May 27, 2008 | NorStar M7310 Corded Phone
Voicemail
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Apr 29, 2008 | NorStar M7310 Corded Phone
NorStar Meridian M7310 Phone Logo
467 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
