Canon PIXMA  iP6700D InkJet Photo Printer Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting a UO71 code saying more than one ink tank is installed. The ink tank is full
Anonymous
Level 3:
President:
  • Master 2,306 Answers
  • Posted on Nov 26, 2009
Anonymous
Master
Level 3:
President:
Answers
2306
Questions
Helped
1130358
Points
8732
Thats a defective cartridge, you need to replace the one whose light is out when they come to the center. Canon will replace defective cartridges for 30 days after purchase.
5helpful
UO43 error there is no ink cartridge there, but when there is an ink catridge UO71 it says more than one ink cartridge
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
Alarm: UO71 more that none ink tank...
That means that you either have a defective ink tank, or there are two of the same color installed, check the label for the inks, the one that flashes is the one with a problem.
1helpful
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Canon MP500 error message
If you're using Canon OEM (branded) cartridges you're going to need to ID the problem chip/cartridge so I'd try and get hold of some empty originals from somewhere (CartridgeWorld or similar perhaps?) and put those in as replacements for one cartridge at a time until you ID the problem cartridge/chip
If they're non-branded then chances are you do have more than one of the same chip but the solution is much the same...
If all else fails, take the printer to a friendly retailer who sell Canons and ask them to help you ID the problem cartridge.
3answers
Alarm light is on and it won't print
I get the same error message. I pull out the yellow cartridge and put it back in. It will print a couple of times and I get the same message. Need a permanent fix.
3answers
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
i had the same problem and when i checked inside to see why it was not working with the cyan i saw that a sensor was the problem... it had fallen out. check it out and let me know if it is the same with yours.
3helpful
5answers
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
3answers
Canon Pixma MP500 UO71 error
I am also getting this error message. For a few days I could take out the offending cartridge and the printer would forget for one printing and then go back to telling me that two of the same cartridges were installed. HELP! I am about to chuck it out the window, though I believe CANON should send us all new ones.
2answers
Pixma mp500
Canon Technical Support team will be able to help here. This seem a common problem with the printer firmware.
old marine
old marine
ZJ Limited
ZJ Limited
