Cnet CWR-854 Router Logo
Question about Cnet CWR-854 Router
Cant access http://192.168.1.254 - Cnet CWR-854 Router
Posted by johninkersol on
Anonymous
  • 788 Answers
The IP address 192.168.1.254 is the default for certain home broadband routers and broadband modems, including
  • some 3Com OfficeConnect routers
  • Netopia / Cayman Internet gateways
  • Billion ADSL routers
  • Linksys SRW2024 managed switches
  • Westell modems for Bellsouth DSL Internet service in the U.S.
This address is set by the manufacturer at the factory, but you can change it at any time using the vendor's management software. 192.168.1.254 is a private IPv4 network address. Any device on a local network can be set to use it. As with any IP address, however, only one device on the network should use 192.168.1.254 at a time to avoid address conflicts.
Posted on Nov 10, 2009
Kit Rolph
    New Friend:
  • 7 Answers
The best solution is to place the broadband installation setup cd into your pc. You need to make sure first that the router is not connected to your pc and also that your firewall is disabled, however, Windows Firewall can be enabled.Follow the instructions that are on screen until you are asked to enter your broadband username and password ( which were decided with your isp ) enter these into the boxes that are provided. Note that you may only be able to enter alphabetical letters, not underscores, commas, etc, etc. Never mind, leave these out and simply fill in the rest and click next! The software will then attempt to make a connection. If you had such things as underscores or whatever in your username, the connection will not be succsessful and you will in due course be told this. Click cancel and remove the cd. you should then see on your screen the router gateway, and you may be asked to enter your username and password. If your router has previously been setup, it's quite possible that after entering this information, all will then be hunkey dorey. However, in other situations if you enter: http://192.168.1.254/ into the gateway browser, you will find that you will than access the advanced gateway pages which will enable you to then carry out a PRELIMINARY setup of your router. A point that needs to be remembered at this stage is this: if you ever need to do a fresh installment of your operating system,ie: WinXP or whatever, your operating system will ask you if you want it to make an internet connection, and of course, for your requirements of setting up the pc with the fresh installation one will say ok. You need to take note that the connection will have to be re - initialised with the steps that I have setout above once you have completed you full re - installation ( although the connection that Windows makes, works, you may notice that your connection is slow, and the led's on the router go " mad "!! ) I hope this is of value to everyone. Chris ( Kitphoenixx )
Posted on Jan 01, 2010
2 Related Answers
Tom Marvolo
Rakesh Warrier
  • 708 Answers
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Posted on Jan 10, 2010
eastpole
Tai Viinikka
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
Why cant I access hull city council site as keeps saying access denied was on it last week but can't access it now
Double check the HTTP://.
Secure websites have an S following the http. ie... HTTPS://
Cant sign into gmail account
Point your web browser at http://www.gmail.com
If another account comes up, sign out of it by clicking the avatar in the upper-right then clicking "Sign out."
If you then still can't sign in to your account, click the "Need help?" link on the sign-in page.
I cant log in my wireless device dlink on http://192.168.0.50/ i want set the password and i cant
the first time you access http://192.168.0.50 it will ask you for username and password. Type the default username and password. If you don't know try one of these:
Username: admin
Password: password
Username: admin
Password: No password (just hit enter after you type the username)
Username: admin
Password: admin
Cant access google home page
cant access google home page
CHECK
type correct web address
software problem -go2 device manager &under device if u see yelow ? mark so tht driver is missing from my computer REINSTALL IT from cd
Else hardware problem thn Replace LAN CARD
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Cant access my d-link wireless access point
Hi, seems you posted twice, here's the link to the your other post with response. http://www.fixya.com/support/t200112-access_d_link_access_point
Top Cnet Computers & Internet Experts
Muzahura Frank
Mehandi Husain ...
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
