Yea I did, just when you put on the Tv you see the channel name, you can see the menu and the close captions, and you getting audio to, it just stop showing pictures Any help?( I did it with cable a DvD and My HDCam)Shane,Thank
Hi.
If you get audio, and TV menu, but you have no raster, then the fault is concerning either the video input/video processing on main digital board, or the optical group.
Lamp and ballast are working since you can see TV menus and closed captions.
Test the TV using different inputs and input cable (you may have gone through this already).
Try at least two different inputs (eg AV cable, SCART, component , HDMI...)
Ensure you use Source/Input button to browse channels.
That can at least tell you if the problem is the video input, or the video processing.
Either than that you will need a technician testing the TV at component level to find the fault.
If you want to contact an authorized technician, or if you want to get a quote on repair, you can call the number listed on the owners manual.
Regards.
