Since your sewing machine his been stored, I suggest you locate a sewing machine repair business near you (preferably one which services you make of sewing machine), take the machine there, and have it cleaned and serviced. You will have to pay for that work.
Hello
Check the filter on the water inlet.
And check voltage on the solenoid when the machine ask for water
Eventually apply correct voltage on the solenoid to check
Good luck
Turn machine off and then back on. That should reset machine. It went off because it did not reach the correct temp in time so the CPU turned the machine off.
Do you have a stitch pattern selected and a length chosen? Otherwise it does not know what you want to do. Sometimes companies neglect to tell you that little fact. Also, how about your bobbin winding shaft, is it pushed all the way to the left? Other than that I am baffled. Good luck.
hello, make sure there is paper in machine, turn machine off, hold the paper feed button, turn machine on, it will print the configuration of machine. adjust serial port setting on computer for baud rate. to change the baud rate on printer, you will need the user guide.
Hold in the "A" button and the up arrow button at the same time and turn the machine on, you can then scroll through the different languages the machine can display using the "A" and "B" buttons.
Make sure the toner is correctly inserted in the machine. If the toner is not seated correctly, the click you hear is the motor turning an auger to try to disperse more toner. and if the toner is not in correctly, therefor no toner is being added, the machine will not start or run anything.
