Question about Hotpoint RFA60 Bottom Freezer Refrigerator
How do I unblock the moisture outlet?
How do I unblock the moisture outlet on my hotpoint fridge freezer RFA60?
The water is overflowing out of the outlet and sitting under my plastic drawers..... its driving me insane!!!!
Is it coming to the end of its life?
Posted by leezw on
jasbo
  • 2,239 Answers
Canned air, wire hanger, anything thick and flexible.
Posted on Nov 10, 2009
Hi there water building up and flooding back from my fridge drain hole.hotpoint model number rfa07
clean ice from drain hole then take a wire hanger and cut it to about 3-4 inches , wrap one end around defrost element anf the other end down the drain hole . use a turkey baster to force VERY hot water down drain hole to clear build up and debris
Feb 24, 2013 | Hotpoint RFA60 Bottom Freezer Refrigerator
I need a new door for the freezer section of my RFA60. Where can I get one?
Instead of replacing the door--- just cover it instead.
Go to www.applianceart.com -- These guys specialize in refacing your appliances. Their motto is Don't replace your existing working appliances -- Reface them. They offer magnetic and vinyl options that will fit over the existing surface. I believe the vinyl option will work best for you.
They have solid colors, designs, textures and even stainless steel options.
Worth checking out.
Nov 14, 2011 | Hotpoint FFA60 Bottom Freezer Refrigerator
Water gathering in pipe in fridge and overflowing into fridge
Hi you will find this is a common problem bits of food get into this outlet and it gets blocked you should have got a small tool with the freezer when you bought it if not use a small screwdriver or smilar item to unblock the hole and you will find this will solve the problem
Mar 17, 2011 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Freezer has defrosted itself fridge still seems to b workin but warnin light for freezer temp is on? Iv tried the fast freeze but it hasnt worked
is this a manual type unit or just a chest type freezer if just a freezer as soon as it reaches a temp of 08 the alarm should stop
Aug 19, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Ice in my fridge
Without seeing this I can't tell you a price or exact fault but the first free thing to try that could likely fix it. unplug the unit from the power and leave both the doors open for 48hrs so the unit is 100% defrosted then try again. cheers.
May 31, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Hotpoint RFA 60 Refrigerator drain problem
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
Jan 18, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
496 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
