When first turned on, the OLEVIA splash screen flickers with interference and emits high pitched noise if you leave it on too long. Turning off then back on sometimes four or five times eventually allows it to work properly.
The high pitched noise is coming from the Tcon board. It is not properly decoding the signal coming form the main board correctly. The only way to fix it is to replace the Tcon board. You might have a hard time coming across the part because Olevia has since gone out of business. Also, usually Tcon boards are not available sepertaly and most manufactures make you purchase the whole LCD panel of which the Tcon is included.
