2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Engine coolant temperature (ECT) sensor
SOURCE: Check engine light VCM code "FUEL 14"?
my manual says fuel fail 14 deals with yourr coolant temperature sensor is no in operating range
