The 9811 is in a car that I do not drive very offen and I can not find my manual. I need to adjust the balance and base and do not reminber how to adjust it. Is their a manual that I can down load?
Are you sure you are using the audio input wires and not the audio output wires on the back of this radio. there is also an input switch you need to set before the Ipod will work
Did you check both the red and yellow wires? You may have a bad connection elsewhere in the vehicle or even bad solder connections inside of the radio itself.
this specific model alpine was famous for that pull the radio out and check the red yellow and black wire were they go into the harness on the back of the radio sometimes the pins in the harness loosen up
you need to set up your system to accept aux. this means you will need to set the 'aux on', as the default setting is 'off'. use the manual and refer to page 23 & 24. please read the instructions carefully, as they are slightly confusing.
Press "Title" until time is displayed. Then press and hold "Title" for a few seconds until time is displayed. Turn the silver knob to change the hour, after hour is set, press the silver knob to activate minutes. Turn sliver knob to change minutes. Press silver knob to end.
