Question about Brother MFC-7340 All-In-One Laser Printer
How i load paper for brother mfc-7340 - Brother MFC-7340 All-In-One Laser Printer
Posted by pancholo0930 on
MrHandyman2
    Sergeant:
    Habit-Forming:
  • 106 Answers
Yeah, user manual is your best guess Brother mfc 7340 manual Download Free Manuals
Posted on Jan 20, 2016
Sean Wright
    President:
  • 2,030 Answers
Here is the link where you can get the manua;l for that printer.
MFC-7340 Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Nov 09, 2009
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: Brother MFC 7340 won't install
Click here, enter detail , and follow instructions to download the right driver for your printer.
Run the file after download has finished.
Note: your product type is a multifunction printer (MFC)
Posted on Feb 23, 2009
Yuk-Wa Chan
  • 133 Answers
SOURCE: Paper Jam
what you need to do is pull out the drum and remove the paper that you can see.
just pull out the drum unit harder.
Posted on May 23, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: How to take out brother tn 330 toner
You open the front door and pull out the drum and toner assembly and then press the blue lever to release the toner from the drum, place the new toner in the holder and install both together into the machine.
Posted on Nov 19, 2009
brett207
brett207
  • 231 Answers
SOURCE: BROTHER MFC-7340 DRUM ERROR PROBLEM
Commonly caused by High voltage discharge or arcing from a dirty primary charger corona and grid.
You need to clean your drum unit.
Open the front door and pull out the Drum unit.
Look on top of it for a small (usually) blue slider, sitting in a 10mm slot that runs the length of the Drum unit. This is the corona cleaner.
Slide this back and forth about 6 times, ensuring you return it to the original starting position.
Reinstall the Drum unit and try printing.....
Posted on Dec 22, 2009
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Mar 24, 2014 | Brother MFC-7340 All-In-One Laser Printer
When I try to print on the MFC 7340, the paper tries to load but stops and a message appears that the paper tray ihas no paper.
It could be the springs that push the paper up are worn out or maybe the rollers are old and worn down.
If the rollers are worn down you can order a maintenance kit and replace them yourself.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-7340 Status monitor offline
Is it giving any errors when you try to print?
Sep 22, 2017 | Brother MFC 7420 All-In-One Laser Printer
I need it to print on legal size paper
Hi there all you got to do is when you go to print it have a place in that driver to change to what size paper you want.
I have put a manual for your printer on my website for you to download.
Just click on the link.
http://www.4all2sell.com/pdf/Brother-MFC-7340-MFC-7345N-Manual.pdf
All The Best Pineworks
Feb 24, 2010 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC 7340
If it is A4, it is too much paper and it is too heavy, it can damage the lift gear. Put half of quantity.
Feb 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
How to print adhisive labels using mfc 7340
Buy laser-specific adhesive labels. Those that say "Laser printer compatible". If you have an inkjet printer, print the labels with it, with the laser is more risky because of the temperature the paper needs to get in the printing process. If one label gets out of the support paper or the paper gets sticky inside the printer, it will cause a real mess.
Try inkjet first, or buy high-quality labels and print one full sheet at a time, not label by label.
Oct 28, 2009 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-7340 All-In-One Laser Printer Logo
616 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
