Question about Sony Cyber-Shot DSC-P73 Digital Camera
Camera won't turn off - Sony Cyber-Shot DSC-P73 Digital Camera
Samsung mhx-w300 won`t turn on
you must press the reset button inside the SD card door. Remove the flash card first. this should allow you to power the camera on.
Feb 04, 2014 | Samsung HMX-W300
Camera won t turn on
What model Vivitar camera? What type(s) of batteries?
Jun 20, 2013 | Vivitar Cameras
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
My Lumix DMC-LX5 camera won't turn on
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
My camera won't turn on and the lens won't close
Perhaps you have bad batteries? Connect it to another power source such as an AC wall outlet and use your power adapter and see if this helps. If it does not or you have already tried this then your camera may need to be serviced.
Jun 29, 2011 | Kodak Cameras
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
Sony Cyber-Shot DSC-P73 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
suresh Kulkarni
suresh Kulkarni
Are you a Sony Camera Expert? Answer questions, earn points and help others
