Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, my stereo is on standby mode and i cant get it to come on! i need to know how to get it off standby, please help my techwood system model plr85
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1188
Points
My stereo is on standby i can unplug it reset it and plug it in and the stereo will come on for aprox one minute pleasde help
Anonymous
Level 3:
  • Master 460 Answers
  • Posted on Nov 09, 2009
Anonymous
Master
Level 3:
Answers
460
Questions
Helped
155515
Points
1449
Sounds like blown output transisters to me .. or a bad relay drive transter and caps...
Anonymous
Level 1:
  • Posted on Nov 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1188
Points
Hi, The problem could also be the thermal fuse inside the main power transformer (AC) is blown. I fixed same problem yesterday. If you have a meter u can check for continuity. Still need help? email me... [email protected]
Mi techwood 400 plr85 Por accidente precione el boton recet y ahora no enciende no se que hacerle
accidents happen but you can not expect any one to know what it did to the equipment if none of us ever had one .
I have a techwood 400 Watt home theater model number plr85 says protected. How do you get it off
Hello Christine, so you mention your Techwood
would have possible problem in the amplification stage
I suggest you disconnect all the speakers and check if it continues to protect, if not, see reconnecting the speakers one by one and testing, control the speaker cables are in good condition
If you repeat the Proteccion fault, I suggest you look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Christine, por lo que comentas tu Techwood
tendr?a posible problema en la etapa de amplificaci?n
Te sugiero que desconectes todos los parlantes y comprueba si se sigue protegiendo, sino lo hace, ve volviendo a conectar los parlantes de a uno y pruebas, controla los cables de parlante se encuentren en buenas condiciones
Si repite la falla de Protecci?n, te sugiero que busques un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf3/66/6543/654206-techwood/plr85.pdf?a40157a995f084aa8ff4e7be48a929e0&take=binary
Techwood Codes
0022,0000,9999. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Check this link too. http://electronicshelponline.blogspot.com/
Techwood TV won't turn on
no you just need a new power supply and mainboard in this unit!
5helpful
My (Techwood 400 Watt Home Theater Receiver PLR85) won't turn on
I have had the same problem.
You have a faulty cooling fan.
The system senses the fan isn't working, and knows that without it, it will over-heat. So it goes into a "self-protect" mode - hence the green light.
You need to replace whatever part of your fan has gone bad.
Ryan
Franklin, IN.
[email protected]
1helpful
Techwood home theater remote code model #plr85
try 212, i have the same exact thing. I used the auto search remote codes method and it found and works on that code...
11helpful
5answers
Techwood 400 watt Stereo Receiver PLR85
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
 Grubhead
Grubhead
SmartAviator
SmartAviator
