Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
What is the difference between a light engine and optical block?
What is the difference between a light engine and an optical block? My Sony has rainbow color splotches all over the screen. KDF-60F655. I heard that there was a recall for this problem, but Sony says that the TV is too old for them to honor it.
Posted by remington223 on
Anonymous
  • 301 Answers
Light engine and the optical block are I beleive the same thing. This is an expensive repair.
I also own a 60" Sony rear projection (2 years old and so far so good).
Best of luck to you.
Bob
Posted on Nov 09, 2009
Anonymous
  • 10,594 Answers
Light Engine and Optics Block is same thing, main part of DLP TV and multimedia projector to produce and project image on front screen.
Few manufacturer call it light engine and some says it optics block.
My tv turning green all of sudden Is there a way to reset it back to it orginal colors
If tv is Sony KDS-R60XBR1 as shown in question headings then it is problem of optic block (light engine) that needs to be replaced, it is hardware problem that wont get solved by resetting. Optic block is expensive part and qualified tv tech is required to replace it.
If tv model number is different, please post it to provide you info about problem.
Thanks.
My sony 60 inch tv plays green is there lenzes in the optical block that crack
You have a defective Light Engine/optical Block.
Call this number and see if Sony will pay to have it Fixed They were extenting warranty on these Models due to so many Light Engines going Bad.
PTS rebuilts light Engines 1-800-844-7871
UED 1-800-648-6657
Encompass Parts Distribution 1-800-638-3328
I hope this will help you.
2helpful
My Sony Grand WEGA KFE50A10 50 in. LCD projection TV has a yellow hue over the picture except for the centre where there is a clear circle of perfect picture. I have replaced the lamp but this has made no...
It is the optical block causing the problem. Sony has had recalls on a lot of the LCD rear projection tv's made over the last 6 to 7 years. The cost of the optical block is around 800.00. Due to the cost, I would check with Sony to see if it qualifies as a recall situation.
I hope this helps,
Skyassoc
4helpful
3answers
Sony Grand WEGA KF50WE610 50 blue hue blue dots
This model also has a paper filter for the Optic block that should be changed. No one ever said anything about it. shortens the life of the optic block if not changed.
2helpful
2answers
What causes 900+ blue dots appear on my Sony rear projection tv?
Dot problem in Sony DLP TV caused by bad light engine (optical block)
Its costly part and needs qualified TV tech to fix it.
1helpful
Not a problem - just clarification
They are the same part. Sony reffers to it as the optical block, while other manufacturers call it the light engine.
1helpful
3answers
Blue haze/blue dots on hd tv
You likely have a bad optical block. Sony was supplying the optical block as a warranty repair until June of this year, but that warranty has expired.
2answers
Sony wega 50"SXRD (green tint)
They are one in the same IIRC. I'm having my TV repair for the same issue. Don't worry for now because the item has had its warranty extended to Oct 08.
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
