1.u can uninstall the cartridges
2.take the power cable out from the back of the printer
3.press and hold "#" & "6" key while the power cable is out
4.while pressing both the keys plug the power cable in and try to connect the printer directly to
wall outlet
5.release both the keys, u will see ur printer will turn on automatically, if it does not press the
power botton and turn it on , then it ask for the language press 11
6.ur printer will start making noise so do not worry abt that and it will ask for the cartridges,
7.install the cartridges
8.when u get ur normal screen of the printer then check the performance
I have similar problem, but it makes clicking sound also without a toner. And printer is powering off and on continuously. On the display there are some bars, nothing readable. After a minute or so it says Warming..., than it goes off, and so on and forth. Printer is in use on a daily basis.
1 **** ageyn put(deliver) the driver.
2 Such happens, when use the cable USB big long or fine.
3 **** USB port from that that ??????????? behind superblock, they reliable, that that on front ??????? of the body they have a noise pickups to inductions.
If fault from fuzer node of the heating, must be on LCD mistake if she there is understand with node
