Whirlpool LER5636P Electric Dryer Logo
Question about Whirlpool LER5636P Electric Dryer
Hoover condenser tumble drier keeps setting off trip switch after running for 10 mts. filters all clean and have checked fuse help!
Posted by d_mackie11 on
Anonymous
  • 84 Answers
Poss. element fault , going to earth , call service agent to check.
Posted on Nov 09, 2009
Error eo2 on drier
This error refers to the thermistor or the thermal fuse opening. It needs to be replaced as there is no way to reset it.
1helpful
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Hoover tumble dryer infinity vison hd condenser keeps tripping after about 3 seconds only had it 6mths? tried fuses, all filters clear and empty.
have you cleaned the condenser down at the bottom of the dryer and pull it out and put hose through it and look in where you have taking it out and make sure its clean and take off back off the machine and see if the element is wet leave it to dry out and if that doesnt help check if the water is going in the tank or your pump could be faulty
Apr 06, 2014 • Dryers
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
No heat from hoover hnv375
If not heat at all check for open heating element.
Sep 06, 2017 • Dryers
1helpful
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
4helpful
I have a Hoover tumble drier model HDC6 type TCMo1 and it is NOT getting hot HELP
Try hitting the reset button on the back side of the dryer.
Yank out your condenser and give it a good clean.
A nice video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
How to clean the condenser in a hoover tumble drier
I normally give it a brush out and flush it if need be with a hose...
2answers
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Top Whirlpool Dryers Experts
Marvin
Marvin
David Shaub
Mike
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
