Question about Kyocera FS-C5030N Led Printer
Kyocera FS c5030n paper comes from the from back rollers not the top
Posted by gtb9104 on
Norman Davis
  • 622 Answers
Close the back cover... or if its broken tape it down...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 23, 2009
  • guzman133 Mar 21, 2011
    What if the cover is closed? My printer won't print while back cover is closed. When I print it comes out from the back and immediately tells me there's a paper jam. I cannot get it to send the printed paper to the top of the printer as before.
  • jimp55 Mar 31, 2011
    I may be having the same problem. I can get the paper to print straight out the back to the optional face up tray, but if I tell the printer to send it to the top of the printer (face down tray), it jams. The problem seems to be that a plastic gate on the fuser section is stuck in one position, and won't pivot properly. It looks to me that it has somehow gotten out of position. Any suggestions would be appreciated. Also, is there anywhere that you can get service manuals for these printers?
Open the fuser for FS-C2126 MFP
there is a blue mark on the right side of the fuser simply pull it towards you and that should allow you to see the rollers and remove paper if not its four screws and three connectors to remove the whole fuser
Jan 17, 2014 | Kyocera FS-C5030N Led Printer
My Kyocera FS-C5030N is printing blank pages
there are a good few possibilities... your cheapest route is to call a local service tech... anything I tell you is going to cost you more... call him and see what he says... but I am leaning towards bad ram best case and worst case a blown main board...
Mar 20, 2009 | Kyocera FS-C5030N Led Printer
I have a Kyocera FS-C5030N, the alignment has gotten off on it, i can't print business cards they are way off now, and about every 10-15 pages i print the alignment is way off, it moves everything up, what...
check the paper size settings.if you are using custom paper sizes, you have to specify the sizes on the printer, otherwise it will think that it has a standard paper size
Feb 23, 2009 | Kyocera FS-C5030N Led Printer
Slow printine
What memory dimms have been fitted.
Print status page see top right. May need more memory and a hard drive.
cheers
May 02, 2008 | Kyocera FS-C5030N Led Printer
I lost my cd
Go to www.kyoceramita.com and you will see a download centre. You can download the driver from there.
Apr 07, 2008 | Kyocera FS-C5030N Led Printer
Printed paper path
sure...check your print manager settings, first, to see if that exit tray is selected as default..
Mar 15, 2008 | Kyocera FS-C5030N Led Printer
Grinding noise and jamming
Try to pull out paper transport unit (when open paper cassette,there is green or blue andle on the printer) and check what is wrong.Maybe just something is in improper position.
Also check paper settings on printer and driver.
If you use 80-90 gsm paper-Plain, if You using heawyveight paper(more than 105 gsm untill 200gsm) -Thick.
BR
Dec 04, 2007 | Kyocera FS-C5030N Led Printer
Kyocera FS-C5030N Led Printer Logo
204 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
