Question about Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker
8 oz kettle does not heat would like to price replacement kettle
Posted by Charles Tripp on
Marks concession repair
    Habit-Forming:
    New Friend:
  • 76 Answers
AFTER YOU FAINT FROM THE PRICE OF A NEW COMPLETE KETTLE, LOOK INTO REPAIRING THAT ONE. IT COULD BE AS SIMPLE AS A WIRE BURNED OFF AT THE CONNECTION ON THE THERMOSTAT OR ELEMENT . ABOUT 2.50 FOR A HIGH TEMP NICKLE RING TERMINAL VS. HUNDREDS OF DOLLARS FOR A REPLACEMENT KETTLE
Posted on Jul 03, 2016
Garry Clelland
  • 251 Answers
Try this link
http://www.vendingmachinesworldwide.com/gold-medal-2014-***-90s-whiz-bang-popcorn-machine-kettle-receptacle-replacement-part-gm49330.aspx
hope this helps
if its not the part you require email them ,
there really good
VendingMachinesWorldwide.com, Worldwide Markets, LLC
2630 Ladue Cove
Fort Wayne, IN 46804
Email us for all inquiries
[email protected]
hope this helps , if it does please vote
Posted on Nov 09, 2009
I have a ccp 600 and the prongs on the bottom of the kettle are broke! Can I get the part or order a new kettle? If so what kettle do I order?
There is a replacement 6 oz. capacity kettle available, but it isn't cheap. The part number is 110600. You can find it at https://www.manufacturedfun.com/parts---110600-kettle-6-oz_v_481_-1,10,101,149.cfm (You may have to copy the link and paste it in a new tab; I accidentally hit the answer button instead of the Suggest Replacment Parts button, and I don't get that back on an edit.)
Mar 15, 2016 | Kitchen Appliances - Others
I lost the instructios for the amount of kernals to put in and if put oil in the well
If you have no idea what brand or model number you have and the kettle is heating properly you can figure it out pretty close just by timing the popping cycle. The ratio is 3 parts corn 1 part oil. so a 12 oz kettle would be 12oz of corn (1-1/2 cups ) to 4 oz of oil. A good popping cycle takes about 3 1/2 min from the time you add the corn and oil to dump time. you can make ajustments for the results you get.
Dec 26, 2015 | Kitchen Appliances - Others
Gold Medal Deluxe Pinto Pop Popcorn Machine Model 2147 will not heat up
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
May 07, 2014 | Gold Medal Products Gold Medal 2147 120208...
Where can i buy a new kettle
Any Creators dealer would be glad to sell you one but when you hear the price you will probably consider repairing yours. Even if the pan itself is bad , I have still repaired them for much less than purchasing a kettle complete.
Apr 03, 2014 | Cretors 14 oz. Antique Profiteer Popcorn...
What keeps the kettle in the upright position while poping?
The profiteer kettle is held upright from the gas spring/shock type unit opposite the handle.
It is very common for the spring to wear out and the kettle to sag after time. I see them replaced about every 2-3 years on that model.
Replacing the return spring will bring the kettle back up to it's horizontal popping position.
Jun 25, 2012 | Cretors 14 oz. Antique Profiteer Popcorn...
I need to order a kettle for my Old Fashion Movie Time Model CCP-509 and I don't know what size kettle it is and where to order it from??
Nostalgia Electrics CCP-509 Movie Time Popcorn Maker
  • Now for the finishing touch -- a full sized popcorn cart that makes delicious, old fashioned, movie house popcorn. The design is nostalgic, but the features are very modern.
  • Tempered glass window.
  • Large stainless 4 oz steel kettle with built in stirring system.
  • Warming light.
  • Kernel catcher.
  • Supplies compartment.
  • Safety Electrics, and easy to clean design.
  • Popcorn never tasted so good at home.
  • Makes up to 1.5 Gallons of popcorn per batch. 4 oz Kettle.
  • Storage compartment in base of unit.
  • Dimensions: 16"L x 19"W x 60"H
Feb 04, 2011 | Nostalgia Electrics Helman Group CCP-509...
How much
Generally, you want a ratio of 3 oz. of corn to 1 oz. of oil. How much corn you put into the kettle depends on the size of the kettle.
Nov 11, 2009 | Kitchen Appliances - Others
Lost Sheets
Nov 10, 2009 | Kitchen Appliances - Others
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Won't heat up.
There may be a fault with the thermstat or the heating element.
Jerry G.
Apr 29, 2008 | Rival 32 Oz. Hot Pot - White
Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker Logo
980 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Adavoid
Level 1 Expert
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
