Question about Galaxy Radios DX-2517 CB Radio
My 2517 talks good after awhile on it it just drop out like dont have no mod but receive good let it cool it go back workin fine any idea? shows when this happens it shows on radio signal moving none on watt meter let cool work fine for couple key down like it runs hot then cool work again?
Posted by shawn key on
Louie Role
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On a MOSFET version of a Galaxy DX2517 and assuming stock mic, heat related issues of missing modulation would require initial checks of:
  • echo circuit - board EB-2000 EPT0SSB51J;
  • mic amp - IC7 NJM4558D;
  • AF power amp - Q53 to Q55.
Good luck and thank you for asking FixYa.
Posted on Nov 12, 2009
Control switch broke on fedders window air conditioner model# M3X05F2A-C. Any ideas what I can do? There appear to be no parts available, but wouldn't a similar switch work?
if you know how to mod it yes ,but I would keep it the same its like talking English ,but all they know is german.
you might damage something elce what I mean is the switch might keep it running at say 1000rpm it wont be this just saying but it tuns 4000 rpm then you find you have a fire hope this helps ,mod if you know how to a switch knows how to talk same English .
Jun 16, 2017 | Fedders Heating & Cooling
Intermittent cooling issues
Sounds like you may have a relay problem, they will cut the compressor off and on until they just go bad all together. Do you here a clicking sound down by the compressor in the back every once in awhile?
Jul 31, 2015 | Refrigerators
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
While watching satellite tv, receiver will work fine for a good while (an hour or more), then you begin hearing what sounds like static in the right front channel, followed shortly after by the receiver...
Sometimes equipment gets too hot and starts glitching. Try an improve cooling and air circulation. Often standing the thing on one end so it's tall will help keep it cool. See if it goes for longer with better cooling.
Oct 29, 2013 | Denon AVR-1911 Receiver
No map dat a available
who need to hook it up to the computer and download the maps back in to the Nuvi. Kinda reprograming if you will. the Garmins usually dont come with the usb cord to conect to the computer but you should be able to buy one. hook it up and download all the maps and you should be good to go. Oh by the way they have lots of cool fetures to download on the Garmin website cool cars and voices, although i prefere for mine not to talk. Good LUck
May 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
Turn signals dont work but still hear the clicking noise
Change the bulbs, my hubby had this problem in a 2002 focus, changed the bulbs and started working again
Mar 28, 2009 | 1994 Honda Civic Del Sol
Modded Xbox 360 gone bad
Mines not modded so i dont know. But when i plug mine in sometimes when i turn it on that happens. I just unplug and plug it in again and it works fine. Check all of the connections but you seem to be smart enough to do that if you modded it
Mar 23, 2009 | Microsoft Xbox 360 Console
Super Star 3900 GHP
Can't help you there. It's most likely that you screwed the modulator up by extending the frequency range. I used to work for Galaxy and I know what happens to a radio when amateurs try to modify them (no offense). If you modify a high power radio such as your Super Star, you're bound to have modulation and SWR problems. In expert advice, never do amateur radio modifications to a high power radio. If you want a more versatile radio, get a Galaxy DX 2517 CB base station. The DX 2517 has PA/FM/AM/SSB/USB/LSB/CW modes, and bands A-F, and a frequency range from 25.615 to 29.205 MHz. The Galaxy DX 2517 has modifications that can be done right at the factory, they are optional however. The only thing I find annoying with the DX 2517 is that it's bulky, it leaves no room for any competition. When it was designed, the engineers left space saving out of the question.
Anyway, Good luck
and
Best Regards,
Gavin93
Aug 07, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Radio Communications Logo
149 people viewed this question
Top Galaxy Radios Radio Communications Experts
Edward Stotts
Edward Stotts
Level 1 Expert
Marvin
Marvin
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
