I bought a Ultraslim Onida yesterday, model: C021SLU250BL, when I put on the TV it is asking me for lock code. When I used the menu option, all the options in the menu are accessible except "Installation" and when I surf the channels after each channel it is asking me the lock code.Is there any issue with set?
SOURCE: DARK PICTURE ON ONIDA COLOUR TV
Check for the loose EHT line (along with the last anode cable),running between the EHT and the PCB of the CRT).It worked for the model 9999.
SOURCE: Onida TV service code needed
press disp+vsm together here it opens service menu at last of that menu there is restore option press 1 to INT . press 1 and your tv will restore.
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
SOURCE: NEC PlasmaSync 50MP2 50 in. Television
hi mate, did you sort this problem out, i have bought same tv but when u switch it on the rgb2 screen comes up and you cant change it by buttons at the bottom, i dont have a remote either.
what universal remote shall i get and how do i enable the buttons at the bottom
thanks.
[email protected]
