Question about RCA 27V530T 27" TV
Needing a picture tube for an rca model # 27v530t
Posted by jasonmatsmom on
Anonymous
    Scholar:
  • 86 Answers
Call partstore at 1-866-925-7278
Posted on Nov 09, 2009
My RCA 27V530T has sound bu t no picture. Could this just be the picture tube?
Hello
There are many reasons for this fault, and picture tube is one amoung them; but a very rare case. Normally, for all picture tube based TVs, short in the windings or the LOT [Line Output Transforemer] is a normal case. If this occures, there will be no picture or screen at all, as all voltages to the picture tube, including its filament voltage are derived from this transformer. Check this first. If it has faulty, the drive transistor [horizontal output transistor] will also will get leakey. First check this transistor. If found leakey, replace it with same type and number. Switch ON the set for a short period of time, say 5 seconds or so, and check the heat of the replaced transitor by touch, after unpluging the set from AC mains. It can be some heat with this transisotr, but it should not overheat. If it overheats, make sure that the LOT said above is damaged, and should be replaced with same type and number. All these components can be bought from open electronic spare part selling shops at your town. You can do this work by yourself at home, provided must have sufficiant testing and soldering equipments; and a sound knoledge in electronics.
If you don't ahve these, get the TV repaired by any experienced service technician, of by the authorised service center for RCA at your town. OK.
Oct 12, 2011 | RCA 27V530T 27" TV
When I turn it on, it makes a buzzy noise but nothing else., no picture or tv sound.
The set has a high voltage problem, "the flyack transformer is defective" It generates the high voltage in the picture tube and with the help of the video circuits it produces a picture. It is not cost effective to repair the tv, cheaper to replace.
Jan 30, 2011 | RCA 27V530T 27" TV
Turn it on i hear a click but no picture, about 10 seconds later the tv clicks again like it's turned off
Sounds like your tube is out. To fix it would cost more than the TV. Try to unplug it overnight and try agian. Post again when you try that and we can try something else.
Mar 17, 2010 | RCA 27V530T 27" TV
My 27'' tube rca tv turns off a little after i turn it on what could be the problem
it may be recieving to much power from the grid and its tripping the circuit breaker to prevent any kind of damage
sorry not sure of how to fix this one
Oct 09, 2009 | RCA 27V530T 27" TV
RCA tv with no picture
problem fixed, check capacitor CV018 100uf between the pin 54 and 55 in the video chip, the capacitor was leaking, also check the board for cracks.
hope it works for you.
Oct 11, 2008 | RCA 27V530T 27" TV
27V530T lines
Reset your TV, and then when it turns on, it will be all set. Not restart, RESET.
If this helps at all, please rate this a FixYa. - Evolution
Jul 16, 2008 | RCA 27V530T 27" TV
Unusable Signal
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
Mar 27, 2008 | RCA 27V530T 27" TV
Horizontal and vertical adjustments
sorry there is no adjustment for this .you probably have a bad component in tv
thanks Doctor video .
Oct 17, 2007 | RCA 32V550T 32" TV
27in RCA
have a tech repair your tv the power supply is deffected.good luck.
May 14, 2007 | RCA 27V530T 27" TV
RCA 27V530T
sounds like you have a bad solder connection on the coil connected to the base of the horizontal o/p transistor. the flyback has the big red wire. ( do not touch, just for reference), to the left and forward a little on a heat sink will be the transistor. on the other side of the heatsink,( a little more forward), you will fond a small coil on the board ir is red & you can see the windings. locate this part on the bottom of the board & resolder this part. good luck.
Dec 24, 2006 | RCA 27V530T 27" TV
RCA 27V530T 27" TV Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
