My agitator is not working so I assume it is the clutch under the agitator but I can not remove the Agitator. I have only tried pulling up on it using lever and brut force.
We had this problem as well, easy answer.
On the back of you fill knob, there is a rubber hose. Blow into it until you hear air flow going through. If you cant blow through it, it's cloged and you can run a fine piece of wire into it to clear it up.
May be inlet valve sticking open or restriction in expansion hose .
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
