Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
My Toshiba 51H84 rear projection tv has lost it's green hue.
Posted by j95snake on
Anonymous
    New Friend:
  • 145 Answers
Open resistor on the green crt board. maybe just turn up screen control on green crt
Posted on Nov 10, 2009
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Toshiba Theaterwide HD 51h84
It is your projector tub if you are getting alot of blue in the picture. Those guns are very expensive to replace. I am sorry to tell you that. It would be cheaper set from wal-mart for your kids to play on.
Nov 23, 2009 | Toshiba 51H84 51" Rear Projection...
I have Toshiba 51H84 rear projection HDTV. There
Open the tv up,but don't touch the lamp use a fan open it high setting blow out everythings should clean it.If not lamp might have scatch some how?
Oct 12, 2009 | Toshiba 51H84 51" Rear Projection...
Toshiba 51h84 color image loses red hue intermitently
You may have a color wheel going bad. Call a good TV Tech for this repair.
Aug 02, 2009 | Toshiba 51H84 51" Rear Projection...
Red crt driver board
you can get the service manual emailed to you at the following link, and they mostlikely have the board yopu need as well just leave an inquirery email and they will respond quickly
http://servicemanuals.vstore.ca/
Jun 04, 2008 | Toshiba 51H84 51" Rear Projection...
My TV clicks, stays on, but still shifts to the left. I have a Toshiba 51H84 51inch
your looking to parts at the convergence area , either check for DRY SOLDER around the power supply area or replace the IC IN THE CONVERGENCE AREA starts with STK- ___ and numbers. try that , hope this helps
Apr 25, 2008 | Toshiba 51H84 51" Rear Projection...
Toshiba 51H84 - Black Screen
try unplugging it and plugging it back in, if that doesn't work make sure that your ANT. cable is plugged in and then check your reciever. Tell me how it works :-)
Feb 19, 2008 | Toshiba 51H84 51" Rear Projection...
Toshiba TN55X81
What's the model number, the TN55X81, or the 51H84?
Jul 24, 2007 | Toshiba 51H84 51" Rear Projection...
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
The solution is you have to buy a new better tv with a good extended warranty in payments. JZ
Jul 09, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
160 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
