The fridge light will ONLY come on if the door switch is tripped. The light will NOT come on for any other reason.
Hope this helps!
It's one of the two, eithere the socket or the switch, if your bulb works on other socket, then that just one of the two i've mentioned.
better get a continuity tester to identify which one causes the problem
About the only way to determine what is causing the intermittent
lighting to your freezer is to do a little electrical testing with a
multi-meter. Also to press the door light switch in and wiggle it around may
help you locate a bad door switch that simply can be replaced if the light
decides to come on only when the door switch is pressed and released a certain
way. Click here=> GE_Monogram_Refrigerator_Service_Manual
Fresh Food and Freezer Light Diagnostics begin on page 46 of the PDF. I will be
here if you have any questions but most of the physical testing will need be
done from your end Testing the bulb sockets for firm connections and a good
steady 12 volts output and 120 VAC input. If helpful please rate, Thanks, Sea Breeze
