I have a 1993 Honda Civic, and it has an old audiovox cassette deck in it that works, but I am trying to install a aftermarket cd player, an alpine CDE-102 to be exact, so I bought the harness to be able to connect it to the wiring, but when I plug in the alpine it won't power on, I have now done this with two cd players, so I know it is not the player being broken, but when I plug the old deck in it powers on and works, so I know it is getting power, does anyone have any suggestions?
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
SOURCE: dimmer wire connection from aftermarket delco harness to alpine
One Of The Wires Should Be labeled Dash Lights That Comes Out Of Your Radio.
SOURCE: 2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not
provide a switched power source. Run a wire to the fusebox for switched
power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
