Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Freezer leaks. Into freezer and refrigerator
Posted by kern70 on
Anonymous
  • Roper Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 27, 2010
Msd2757ae freezer leaks water
Leaking Refrigerators Just What may Be Happening
I am pretty sure you are having a defrost drain blockage problem, and click here=>
Leaking Refrigerators! Let me know if helpful, Sea Breeze
2helpful
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Freezerator leaking water into freezer that is freezing in bottom of freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
2helpful
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Freezer ices over then leaks into refrigerator. Have to defrost drain line every few weeks or so
Try changing your temperature of the freezer on full. This should prevent the freezer from leaking and causing a main problem. If this still keeps happening try and lay down some kind of covering to prevent it from leaking.
Hope I helped Dr Reed
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Water leaks into the freezer
under refrigerator you soposed to use hot water
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Ice at the bottom of the freezer
It sounds like the freezer has leaking door seals and air is getting in to the freezer compartment. Your temperatures are set about right. Regards
Top Roper Refrigerators Experts
Steve
Marvin
Marvin
john h
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
