Question about Epson Stylus C46 InkJet Printer
The epson c46 printer cartridge doesnt move for printing
Posted by ma_rapgame on
Sean Wright
    President:
  • 2,030 Answers
It may have become jammed, open the cover and see if anything is jamming it such as paper.
See if with the power off it will move to either side with a little pressure.
The c46 is a cheap disposable printer, and may have just got to the end of its life
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Nov 08, 2009
Trying to print n a epson printer without black ink carthiage
Unfortunately the Epson stylus needs both ink cartridges to print. I've tried useing an emty cartidge to "fool" the printer,but that won't work. When my Epson was ready for replacement I bought a printer (Lexmark) that prints with one cartridge empty.
Dec 27, 2010 | Epson Stylus C46 InkJet Printer
My epson c46 is not printing black
Is the black ink cartridge empty? If not, have you tried cleaning the print heads? Sometimes, if printers are used a lot, or used and then left unused for a long period, ink can dry on the print heads. While this usually just results in bad print quality, in extreme cases it can prevent the ink from printing at all. Check this article for directions on cleaning the print head.
Feb 19, 2010 | Epson Stylus C46 InkJet Printer
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
EPSON C46 problem with color cartridge
The Epson does not like Generic Cartridges. It must be Epson Genunine Cartridges. After going thru alot of ink cartridges, finally I went back to Genuine, and it started printing fine. ! Go Figure. !!!
I have about 2 dozens cartridges. hahaha want them?
Good Luck :0)
Nov 16, 2009 | Epson Stylus C46 InkJet Printer
Can't change carteridge, inaccessable
If this is not mechanically block. You can use the epson reset program. Key in " epson reset software" to web search bar the uppermost link. It have a feature to move its ink cartridge to exchange cartridge position.
Apr 27, 2009 | Epson Stylus C46 InkJet Printer
C46 printer. red light is permanently on.
Your printer was reach its maximum print warranty... it has a resetter.. try this link...http://www.ssclg.com/epsone.shtml
Mar 10, 2009 | Epson Stylus C46 InkJet Printer
My printer wont print, and i think theres dry ink in the dispenser, but i dont know how to take it out, because the cartridge holder doesnt come out. i have an epson stylus colour 760. btw, i DID change...
Hi
Try running the head cleaning cycles from printer utility. then try reprinting. You can press ink button for 3secs as well to auto clean printhead.
Hope this helps
Nov 29, 2008 | Epson Stylus C46 InkJet Printer
Not registering print request
you need to reset your printer let me no if you dont have the tool and i will give it to you
Oct 28, 2008 | Epson Stylus C46 InkJet Printer
My C45 printer doesnt print anything inthe paper
Could be the jts are clogged in which you will need to do deep cleaning routine You will need to down load the ssc untiliy for for this - www.ssc.lg.com for this. or devise the cleaner syringe- see the picture.
Jun 14, 2007 | Epson Stylus C46 InkJet Printer
Problem with my printer
well first here http://emeasupport.epson-europe.com/downloads.aspx?LNG=EN-EU&Search=1&data=1bANIZf8BRVoS83cS1PVis/kIVxbLcWZ9JD5vhjblgJTVeIjQGvfyu2+tOhzwN03 for more info & your drivers but what you need is new ink cartages
May 25, 2006 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
