Question about Teac PLD2000 System
My TEAC PL2000 DVD only plays some DVD's
Hello !
My TEAC PL2000 DVD only plays some DVD's, and do not recognise others DVD's (and I'm sure it's not a problem with region codes).
Can anyone help me ?
How to see it's firmware version ?
Must I upgrade the firmware, and how ?
Thanks.
CSantos
Posted by carlos_mo_sa on
Muntejaya Ginting
  • 10,422 Answers
Hello, Please get the code here : www.dvdoverseas.com/dvd.htm
www.regionfreedvd.net/
Regards, Jay__)omnjk
Posted on Feb 25, 2011
Does anyone know how to de-code or hack a TEAC DV-H500 cd/dvd player. After owning for several years i still can't play or watch many disc's. Many Thanks
This works with some dvd players, don't know if it'll work with yours... With the remote, open the tray... punch in 9,9,9,9...and then enter, and then '0' and hit enter again. This breaks the region code or allows playing of any disk.
Jan 06, 2011 | Teac DV-H500 DVD Player
My TEAC CD-224E plays some DVDs and I don't now how 2 make it play the others like DVD optains one movie or more
If your DVD player is set to a DVD region, then it cannot play DVDs from other regions. You are allowed to change the DVD region only four times, then the DVD player will lock permanently on that region.
If your DVD region is locked then you can install a program that will allow you to play DVDs from any region.
Please click on this link for details of a DVD region program :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Nov 10, 2010 | Teac CD-224E Plug-In Module 24x CD-ROM...
What does it mean when my dvd player says wrong region??
DVD's are coded to play in different parts of the world. Each DVD player is set up to recognise these codes. Most are set up to recognise only the region code of the area it was made for. For example Region 1 is for the USA and Region 2 is UK and parts of Europe. A DVD player made for the USA market would not be able to play any other discs with a Region code other than 1. And so on... This was done for the film industry benefit so that films can be released at later dates in different parts of the world without everybody seeing it on DVD issued in the USA.
However most DVD players can be "hacked" by a combination of keys allowing the user of say a Region 2 player to change it to another region. Some can also be changed to Region 0 which means it should play any disc.
How to change the Region code can be found by putting the model number of the DVD into a search engine and the words 'region code'. Some can be found on this site too.
Dec 04, 2009 | Electronics - Others
I have this exact problem!
I found a couple of region 1 DVDs and tested them in the player they worked so that's the solution?!
Jun 19, 2009 | Teac DV-3000 DVD Player
Region Unlock TEAC PL-D3200
Multizone code for Teac PL-D3200 Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Nov 28, 2008 | Teac DV-H500 DVD Player
Teac PL - D3200 unlock coce
Apr 14, 2008 | Televison & Video
Unlock codes for TEAC PL-D2000
Comments:
To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region
Ensure TV monitor is on so and set to display DVD.
1. Turn system completely off.
2. Turn on system.
3. Open tray.
4. Using remote press and hold the return button.
5. While holding the RETURN button, press and hold the DISPLAY button.
6. You will see something like this displayed on screen: VER 1006 TE 3210
7. Release DISPLAY and RETURN buttons simultaneously.
8. Press the ANGLE button. You will see WRITING REGION ID displayed.
You can now play DVDs from any region.
Dec 28, 2007 | Teac PLD2000 System
Hacking code for Teac PL-D3200
Sep 16, 2007 | JVC TH-S8 System
Teac PLD2000 System Logo
Top Teac Audio Players & Recorders Experts
efs_perpends
efs_perpends
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
