Kohler K-12176-PB  Fairfax Single Handle Kitchen Faucet With Side Spray Poli... Logo
Posted on Nov 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kohler Fairfax faucet pressure /flow has dropped (cold)
I have a kohler fairfax faucet and recently the cold side pressure has dropped in 1/2. Hot side OK. I changed out the main valve assembly and it had no effect. What could this be?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
712
Points
There R three things to do :
1.Verify water pressure is correct from water source. Do this by removing the supply line, using the shutoff to remove one end and test the other.
2. Take the handle off and retaining nut loose to remove and replace the inner plastic cartridge
3. Another often problem is that the sprayer and faucet act up when using the sprayer or the cold water quits all together and starts working again. The solution is a spay diverter part in the inner workings of the faucet.
Anonymous
Level 3:
An expert that gotĀ 10 achievements.
President:
An expert whose answer gotĀ voted for 500 times.
  • Master 1,015 Answers
  • Posted on Nov 08, 2009
Anonymous
Master
Level 3:
President:
Answers
1015
Questions
0
Helped
451778
Points
3407
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
3 Related Answers
Anonymous
  • 3600 Answers
  • Posted on Sep 27, 2009
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Anonymous
  • 8197 Answers
  • Posted on Mar 19, 2010
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Fred Yearian
  • 5603 Answers
  • Posted on Dec 29, 2010
SOURCE: Kohler Fairfax kitchen faucet has
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
I have a Kohler Fairfax 12176 kitchen faucet and it is about 4 years old. It is starting to leak water out of the spout for a split second on occasion when you turn the water on. As time goes on, it is...
Kohler K-79402-CP aerator kit
Kohler K-78250
Kohler 1001100
You might try to replace aerator on end of spout if water is leaking around it, or you might try to replace cartridge. VALVE (CORALAIS AND FAIRFAX)
K-GP77548
$14.80 List Price
Call Kohler if you need more info.
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
Our Kohler Fairfax kitchen faucet 12176 has a difficult spout swing from side to side that I thought would get easier over time. It is installed on granite and when I use hot water is very difficult to...
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
2helpful
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
