Bialetti Stovetop Espresso Maker Espresso Machine Logo
Question about Bialetti Stovetop Espresso Maker Espresso Machine
I have just blown the valve on my bialetti cappuccino maker, can I reuse it?
Zlobomir
    Sergeant:
  • 225 Answers
The valve no, it is dangerous. Steam under pressure is a bomb. If you can detach ?unscrew? the old valve and find a new one, it will be fine.
Posted on Nov 08, 2009
Testimonial: "thanks for fast response"
Operation manual for vintage bialetti gran gala cappuccino electric machine
http://www.espresso-machines-and-coffee-makers.com/bialetti-moka-express.html
Bialetti Coffee maker repair
Sure it can. http://www.bialetti.com/coffee/stovetop/moka-express/spare-parts-c-1_7_22_32.html or http://www.amazon.com/s/?ie=UTF8&keywords=bialetti+spare+parts&tag=googhydr-20&index=aps&hvadid=32661633397&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3217975301600862448&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_53u2x7ta30_b
Muka express bialetti leaking
Easy!! Not making coffee or cappuccino, go to Starbucks less issues LOL
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine,...
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
2helpful
I was looking for instructions for a Bialetti Mukka Express ;and also does this unit make espresso?
Here is the owner's manual. Also, by filling the filter with espresso grounds and using water, you are making espresso. It only becomes cappuccino by adding milk.
http://www.google.com/url?sa=t&source=web&cd=5&ved=0CEcQFjAE&url=http%3A%2F%2Ffantes.com%2Fmanuals%2Fmukka_express_manual.pdf&rct=j&q=Bialetti%20%22Mukka%20Express%22%20owners%20manual&ei=JdWATp7uLcu4tge7prWNAQ&usg=AFQjCNEIi9J9flq7TmgLWUYOiLF4KatH3g&sig2=UqfzIzEfVCpfZv60t1wClg
1helpful
Very rarley froths, is it worth buying a new valve (which I have just blown)?
To replace the valve and have it repaired may not be worth it. Just buy a new one. Repair cost could be expensive, since it does not function well (rarely froths).
We cannot be sure as to its usability.
7helpful
Bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Top Bialetti Coffee Makers & Espresso Machines Experts
Marvin
Marvin
David Shaub
Kolbrun...
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
