Question about Konica Minolta DiMAGE Z3 Digital Camera
Dimage z3 system error - Konica Minolta DiMAGE Z3 Digital Camera
Posted by thisldooau on
4 Related Answers
Anonymous
SOURCE: Dimage Z3 System error
plug it in, right click on it in my computer and select format, tick the quick format box and start it up! this will sort it out, i believe the problem is caused by incorrectly disconnecting the camera from a pc/laptop, so when you next disconnect make sure you safely remove it (right click in my computer,select safely remove)
Posted on Jan 14, 2009
fikretunalir
FIKRET UNALIR
  • 239 Answers
SOURCE: need an owners manual for my knoica minolta dimage z3
This is Konika Minolta DiMAGE Z3 complite Instruction Manual
Posted on Mar 03, 2010
Ty Price
  • 11967 Answers
SOURCE: why does my dimage z3 memory card say card full?
Did you delete them on the computer or the camera? If they are safely on your computer, you can erase and optimize the card for the camera by going into the menu and finding "format"...follow the on-screen instructions.
Posted on May 09, 2010
Anonymous
SOURCE: my Dimage Z3 camera shuts down on a 'system
Hi , just solved, I think the very same problem that you have with your Z3. I got the some of the solution on a similar web site. Here's what worked for me. I connected my Z3 to my PC in the normal way. When I turned it on it stayed on and did not immediately cut off. I was able to see all the photo's on the 1gig card. Some were corrupted and there was a lot of duplication. I was able to download all the photo's onto the PC. Once I was sure they were there I was now able to format the card by using the PC. This seems to have solved the problem for me.
I think that I may have caused the problem by trying to download photos when I may have had to much vino to drink!!!!!!! I ended up duplicating photo's instead of downloading them and trying to stop this in mid-stream may have caused the camera to ingest a gremlin. Also the battery ran low when trying to download and cut the camera off. Hope that this works for you.
Posted on Mar 01, 2011
Turn on camera and system error screen comes up and you cannot do anything to camera.
1st you need to update the firmware to 1.3u
download firmware here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/index.html (this allows 2GB cards)
instructions are here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/firmware/installation_guide.html
(instructions are a little vague on where macro mode button *flower button* is)
Also, you might have a bad SD memory card. format the card (erasing all data/pics on card)
and take some picks and try again.. if you can
If still a system error try a different SD card to get past error then update firmware with THAT SD card.
IF that don't work.... your hosed... ;(
Nov 17, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
Why does my dimage z3 memory card say card full?
May 08, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
Jul 01, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
What metering mode does the DiMAGE Z3 employ?
The DiMAGE Z3 employs three types of metering mode: multi-segment (256-segments), spot metering and center-weighted.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
What OS does the DiMAGE Z3 support for USB connection?
The DiMAGE Z3 supports Windows98, Windows98SE, Windows Me, Windows2000 Professional, WindowsXP (Home/Professional), MacOS 9.0-9.2.2 and MacOS X (v10.1.3-10.1.5, v10.2.1-10.2.8, v10.3-10.3.3).
How can I playback and edit the captured movies?
The movies can be played back on the DiMAGE Z3. They also can be viewed on TV by connecting the camera and TV via the AV cable. Playing back movies on PC is enabled by installing the QuickTime, ArcSoft VideoImpression Version2 (Windows only), and DiMAGE Viewer
Konica Minolta DiMAGE Z3 Digital Camera Logo
Top Konica Minolta Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
