I just purchased a dvd player and it's showing vertical lines.
I just purchased a dvd player and ''plugged'' it into the back of my TV. When I switch the TV screen from ''TV'' to ''Video,'' instead of getting the projected image of the dvd I want to watch I get a lot of vertical lines. Not only that but the image coming from the dvd appears to be black and white instead of color. What did I do wrong, if anything, and how do I fix it?
--Gary
Posted by davidgary94 on
Anonymous
    Scholar:
  • 54 Answers
PLEASE CHECK PAL AND NTSC SELECTION....IF YOUR REGION IS PAL SELECT PAL IN DVD SETTINGS....OR IF YOUR REGION IS NTSC THAN SELECT NTSC IN DVD SETTINGS....ITS NOT A PROBLEM...JUST TRY TO SWITCH PAL AND NTSC IN YOUR DVD SETTINGS....U WILL DEFINATELY GET THE RESULT
Posted on Nov 08, 2009
Dvd player is playing a vertical split screen
If the TV does the same with two different DVD players, it must be a menu setting on the TV. Look through the TV menu options.
Jul 24, 2013 | Panasonic DVD-RP56 DVD Player
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
I have a thin yellow line in the center and vertical on my toshiba 50
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Toshiba 50HP66 50 in. Plasma Television
Thin vertical line on LCD tv
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | iLO V27DMBX Television
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
No sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
May 24, 2009 | Philips Magnavox 27MS343S 27" TV
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Samsung LE32R7 Vertical lines problem
Plug the TV into a wall socket by itself, have seen this when TV was plugged into a power strip.
Dec 13, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Vertical lines moving from right to left at about 60 cycles
Probably solved long ago, but this sounds like RF interference. Is there a radio or television transmitting site within a few miles of your location? Or it could be the projector itself causing interference to the circuitry within the player yet not be a problem with any other source. Try it with another TV with the projector on and off. Even a small black and white will do.
Nov 11, 2007 | Pioneer DV-F07 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
