Question about Frigidaire Dishwashers
My dishwasher is now leaving my dishes cloudy. What causes this?
muebe
    President:
  • 1,015 Answers
Make sure that the rinse-aid(jet dry) container is full. If it is full have you noticed if it's level has not dropped. It is possible that the rinse-aid dispenser is plugged. This will cause the dishes to be cloudy. You can also try running the dishwaher empty and add a cup of vinegar to the bottom before your start. There is also this stuff called "dishwasher magic" that you can try running in the dishwasher to clean it. Try using a soap with the rinse-aid in it or install a basket with a rinse-aid tablet and see if that helps clear up those cloudy dishes.
Posted on Nov 08, 2009
Testimonial: "You wereso fast with a solution thanks"
Mike
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. that is what makes dishes cloudy. its calcium and magnesium dried on the dishes. www.dishwasherfilter.com has a great, affordable product for this exact problem. it will filter the water going into your dishwasher leaving them spotless every time. check it out. guaranteed to work or your money back.
Posted on Nov 12, 2009
5 Related Answers
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: my dishes are coming out with a thick cloudy film
ok ,,,first just run a pint bleach wash,,now on your next load,,check your water temperture..is the water over 140 degrees...to hott...onthejob
Posted on Feb 18, 2009
Anonymous
  • 31 Answers
SOURCE: my dishwasher leaves a cloudy residue on my dishes
The cloudy residue that is left on your dishes is soap that has not completly broken down.
There are a few solutions to the problem. First off, you want to ensure that you are using the "high temp wash" option. This will boost your water temp during the wash cycle to ensure that all the soap breaks down.
The second thing that you want to do to give your dishwasher a boost, is run the hot water in the sink and make sure it's pipping hot before you start your dishwasher. What this will do is ensure that the water that goes in for the "pre wash" portion of the wash is hot and will improve the wash quality.
Posted on Mar 01, 2009
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: cloudy dishes
Hi there.
You will need to get some cleaning detergent so you can clean the jets and the internals of the machine, once the clean has been done you should end up with clean dishes.
Good luck and thanks for using FixYa!!
Posted on May 11, 2009
Mike
  • 677 Answers
SOURCE: cloudy residue on dishes after washing dishwasher is only a year and a half old what can i do ?
you need to check out this new product designed especially for this problem. it is guaranteed to work! it filters the water going into your dishwasher removing the hard minerals that cause these spots. get it at www.dishwasherfilter.com
Posted on Jul 07, 2009
Anonymous
  • 77 Answers
SOURCE: CLOUDY DISHES IN DISHWASHER
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Posted on Apr 04, 2010
Dishwasher dishes cloudy and makes loud buzzing soundf
I am not sure about the buzzing but cloudy dishes is caused by
hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 03, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Not sure what model but Frigidaire Dishwasher- the dishes are cloudy and gritty. The water gets hot, the cycle seems to be running normally, but even if I put clean dishes in, they come out cloudy and...
The problem is hard water leaving those spots. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 20, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My dishwasher is not cleaning the dishes properly it leaves food on some of them. Is it gettin enought water? what could the problem be if not. It is 1 1/2 years old. thanks MAB
If the dishes are spotty or cloudy the problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 19, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Glassware is cloudy
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Nov 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes always come out cloudy ... white cloudy stain on inside of door, etc. We use electrosol power ball cubes. We set wash cycle to normal wash.
Oct 18, 2009 | Maytag MDB7100AWB Dishwasher
Food left on dishes, and glasses are very cloudy. We use rince aid, and have tried several detergents. Water temperature has been turned up twice.
Oct 01, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Cloudy dishes
Sep 22, 2009 | Maytag MDB9100A Dishwasher
Cloudy Glasses
The problem is hard water and jet dry will not solve that. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Jun 01, 2009 | Dishwashers
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
Dishwashers Logo
545 people viewed this question
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
