If there is one it will be on side or front of the computer. You can always buy a sd card reader that plugs into your usb port.
Try buying a SD Card Reader that reads many formats from Tiger Direct at:
http://www.tigerdirect.com
When the site comes up just type: SD Card Reader in the white search box at the top of the page then click GO.
Or if you camera came with cables you can plug one end into the camera and the other end into the computer's usb port and turn the camera on. The computer will recognize it and you can search through the folders on the camera for the pictures.
The IBM ThinkPad Z61t computer runs the Windows operating system. Normally, Windows is displayed on a monitor in a manner that makes it easy to read. If you want to change the screen display configuration (from vertical to horizontal), modify the screen display properties in Windows itself. This process causes the computer to rotate the image displayed on the screen by 90, 180 or 270 degrees, depending on the setting you choose.
1.Right-click on an empty portion of the Windows desktop on the Z61t.
2.Click "Properties."
3.Click "Display."
4.Click "Change display settings."
5.Click the "Orientation" drop-down window. Select the "Landscape" option to make the screen display items in a horizontal manner.
I believe the features of the function (Fn) keys vary on different models.
This webpage from Lenovo Support covers the ThinkPad R60, R60e, R61, T60, T60p, T61, Z61e, Z61m, Z61t, you may have to search your model as it may be different.
Hi, the standard reset solution for laptops is to remove AC power and battery then hold down the power button for one minute to clear the memorys. In my experience this only works for a limited number of laptops. The alternative is to open up the laptop and remove the cmos battery overnight which works in most cases. If this is a modern IBM and reading between the lines you are asking this question in order to clear a bios password then neither method is likely to work, worth a try anyways tho.
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
