Question about LG Dishwashers
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
The bottom spray arm on our LG dishwasher, Model LD-14AW3, will not spin. I don't know if water is coming out. Plates etc in bottim basket do not get cleaned.
Posted by willo512 on
Anonymous
  • 464 Answers
Sounds like no water going into the machine. you may need a water inlet valve.
Posted on Nov 08, 2009
The spray arms aren't spinning, any ideas?
The main water pump sounds to be defective, not supplying enough water pressure to turn the spraybars.
Nov 05, 2015 | LG Dishwashers
LG LD-2040WH Dishwasher problems: It appears the bottom spray arm of my dishwasher no longer rotates or sprays. I had to replace it several months ago and the new one has been fine until now. I removed it...
this dishwasher had many design flaws that generally cannot be fixed even with multiple service calls. lg has scrapped the design and replaced it with their "direct drive" line of dishwashers specifically to remedy the problems with stationary spray arms. my advice would be to replace the unit.
Sep 26, 2013 | Dishwashers
Ld-1416T
If you have one spray bar working then there is enough pressure. There is only one pump. So you should check the spray bar to see if it is plugged. Also check the seals to see if they are bad.
Jun 08, 2013 | LG Dishwashers
The bottom spray arm on our LG dishwasher, Model LD-14AW3, will not spin. The diverter valve from top to bottom section does not operate, i cleaned it and the housing near the filter but still no go. any...
I have the same problem, well - similar. The diverter is moving for me, however it is moving to the wrong position. It seems to move between the upper arm and then blocking off, rather than upper arm and then lower arm.
Did you manage to find a solution?
Mar 25, 2011 | LG Dishwashers
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG modelLD-1403W dishwasher. The bottom spray arm
The wheels on the bottom rack could be broken or collapsing..or the rack is distorted or bent..or the spray arm is not attached correctly or is damaged.
Nov 08, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Top arm in dishwasher will NOT spin!
When you say the top arm does not spin, remember that the LG model x811 family has the Vario feature that alternates between routing the pumped water to the bottom arm and then the top arms alternately. So anytime the dishwasher is washing and rinsing, either the lower or upper arms will be spinning.
If the problem is not above, then the motor that drives the check valve may have failed (or the check valve is obstructed inside.)
Hope that helps. Please post back here with what you find, OK?
Sep 04, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
LG dishwasher bottom arm not spinning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
syte
Aug 24, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
657 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
